Wed, Jan 8, 12:47 AM CST
Subject: zbrush to poser morphs question
Darkworld ( ) posted Mon, 30 November 2015 at 2:46 PM · edited Mon, 06 January 2025 at 9:04 PM
Ok, so I can make morphs just fine in Zbrush but i have to work with one body part at a time. How would you make a morph across multiple body parts?
I can export WITHOUT welding seams from poser, say export head + eyeballs + upper jaw + lower jaw. But then in zbrush everything is stuck together. How can i split it up?
Ideally I will EDIT the thing altogether to make a smooth morph, then export the parts individually so they are legal in poser. I know people build morphs this way I'm pretty sure it's how they did the entire creature creator pack.
Thanks for any tips!
AmbientShade ( ) posted Mon, 30 November 2015 at 3:11 PM
Import the figure's .obj directly from the Poser runtime, not as an export from Poser. Do the sculpt across the whole model, then import it back into Poser as an FBM. It will only show on the body parts that you morphed and under the main Body group as a master parameter.
EldritchCellar ( ) posted Mon, 30 November 2015 at 3:21 PM · edited Mon, 30 November 2015 at 3:28 PM
In zbrush cntrl + shift clicking a welded grouped mesh's various groups will let you selectively hide and unhide the groups, cntrl clicking the canvas allows you to quickly mask visible groups. You want to create your morphs on welded meshes to avoid body part seam distortions. Work from the .obj in geometries, not from an exported .obj from scene .cr2... unless you have a very specific reason for doing so involving group manipulations and spawning props/targets. V4 is a welded grouped mesh, work from her obj in geometries.
EldritchCellar ( ) posted Mon, 30 November 2015 at 3:22 PM
Sorry Shane, crosspost.
Darkworld ( ) posted Mon, 30 November 2015 at 3:32 PM
Sweet that is extremely helpful thx guys ;)
kerwin ( ) posted Wed, 02 December 2015 at 4:12 PM · edited Wed, 02 December 2015 at 4:13 PM
If you have PoserPro (10 or 11) you can use Export Figure Mesh to GoZ. It will allow you to send the mesh with either part grouping or material polygrouping. If you're worried about accidentally modifying something you don't wan to modify, just hide the polygroups before Zbrushing. Be sure to unhide before using GoZ to send the morph back.
With this method, Poser and GoZ handshake to save you the effort of worrying about welding/grouping/exporting/importing/etc. It also allows you zbrush on a posed figure (not just the standard "T" position.)
(The other methods work great too, but I like that GoZ handles the import/export pipe for me.)
-K
