Sat, Feb 1, 4:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Trouble with Models
pa902 ( ) posted Sat, 27 November 1999 at 5:01 PM ยท edited Thu, 30 January 2025 at 12:01 PM
I just started creating models with True Space4 and saving them as .3ds files -they import fine into poser but when i created some using boolean subtraction when i import them into poser they show up as solid-i even tried them in Bryce and got the same thing-they look fine in True Space-what the heck is going on? If someone can figure this out id really appreciate it-thanks....Pa902
pa902 ( ) posted Sat, 27 November 1999 at 5:27 PM
yea theyre solid all right-i spun them al around-in bryce i could even select the negative objects-they didnt show up as anything-i tried making them negative and the other ones positive and still they were solid
pa902 ( ) posted Sat, 27 November 1999 at 6:11 PM
Ok this is bizarre-i boolean out a cube to make it an L shape and it shows up fine in both programs-but when i boolean out the cube to be hollow like a box it show up as solid-i cut the top off of it in bryce and sure enough its hollowed out but the cubes appear like thin paper-like the walls of the box are hollow-someone out there has to have true space or had this problem before-its like the boolean will cut things up but it wont hollow things out-although i did hollow out a sphere to make it like a cup and that imported fine-it seems to be just with the cube when i hollow it out like a box-sheesh-only me :-(
DM1234 ( ) posted Sun, 28 November 1999 at 1:01 AM
I have TrueSpace4.3 and I just tried what you said you did with the cubes. I got the same results you've described with it in Bryce. That is strange? DM aka Nite Miner I'm going to try a few things. this is bugging me.
pa902 ( ) posted Sun, 28 November 1999 at 4:48 AM
So im not crazy!!! -well I might be...BUT NOT IN THIS INSTANCE!!! Anyway-its really good to hear this-I have true space 4.2 and I wondered if 4.3 had the same problem-well i guess it does-keep in touch Nite Miner-this really is BS!
DM1234 ( ) posted Sun, 28 November 1999 at 10:55 AM
I've tried this now with more setting changes then I can count and still ends up the same. Tried it in cob format and still the same. Although I've not had a situation where I needed to import such an object into Bryce from TS yet. I sure would like to know I could do so. If you come up with a solution to this pa902, let me know. Nite Miner
dlfurman ( ) posted Sun, 28 November 1999 at 3:35 PM
Try saving as Wavefront Object (.OBJ) and see what happens.
pa902 ( ) posted Sun, 28 November 1999 at 3:51 PM
Tried it
Mason ( ) posted Mon, 29 November 1999 at 11:43 AM
Booleans in some packages are procedural meaning its kind of like executing code to make the shape show up ie. "this shape is a box minus a cylinder" instead of "this shape is a polygonal mesh that looks like a box with a hole" mesh. In 3DStudio I reduce the final object to a mesh. I don't use TRuespace but I would imagine there is a way to tell it to reduce your object to an editable mesh. From there you'll have the true polygonal mesh and can export fine.
pa902 ( ) posted Mon, 29 November 1999 at 8:36 PM
I cant seem to find any way to convert the mesh and its really pissing me off-you are right though because when i bring the model into bryce the second cube is still listed under meshes-unbelievable
DM1234 ( ) posted Mon, 29 November 1999 at 11:58 PM
In Bryce it only shows up as 1 mesh object for me. Create the same boolean in Bryce and you'll still get the same result as one imported from TS. pa, my ISP used a bigger hammer so I was able to reply to your e-mail. DM aka Nite Miner
