Sun, Feb 2, 6:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: Anyone else notice this with collision detection?
jbearnolimits ( ) posted Wed, 02 December 2015 at 6:37 AM ยท edited Sun, 02 February 2025 at 3:54 PM
I was using collision detection on a couple of figures (m4 and v4) and for some reason it seemed like poser just freezes for a little while when you pose the figure and it makes contact. I was wondering if this is normal or if it is a problem with too many resources being used on my cpu when this happens? So does it just happen to everyone? Using poser 8 by the way.
hborre ( ) posted Wed, 02 December 2015 at 8:22 AM
Online Now!
Collision detection does take quite a bit of memory when activated. I have seen slowdowns with past Poser versions.
Morkonan ( ) posted Fri, 04 December 2015 at 12:48 AM
I'm not sure that Collision Detection, as I know it, works that way. It's basically a rendering "intersection detection" algorithm that, when activated, will place the rendered surface in "front" of a surface that is colliding/intersecting with it. (But, only in small increments - It's a very "iffy" solution for small poke-throughs.) It works in the renderer and doesn't have an effect, that I know of (and I might be about to learn something new, here) in the Preview pane. (ie: I don't think the OpenGL renderer pays any attention to it.)
IOW - It's not really a "physical collision detector" sort of thing, unless I'm waaaay off the mark and you're talking about something else. However, if it did do something in the Preview pane, I would certain cause some extra processing. I just haven't noticed any effects, but it will slow down a render a little bit. (Don't click it on for hair models unless you've packed a lunch...) I don't know that Poser 8 has any physics modules besides that balance thingie toggle and those provided by custom python scrips.
