What version of Poser are you using? If you have Pro 2014, are you using the Poser Fusion plugin?
Here is a very old tutorial on how to get V3 into Max. https://www.renderosity.com/mod/tutorial/?tutorial_id=499
Two more: https://www.renderosity.com/mod/videopro/?View=Y&video_id=27 https://www.renderosity.com/mod/videopro/?View=Y&video_id=29
First I export the figure as a .obj file. I make sure that all the needed textures are accounted for when loading in Max. The textures appear, except the head textures. the figureโs face is just a shiny silver-like material. When I manually assign a texture I does not appear on the figure. The hair texture appear in the preview only. In rendering it, you see the bald head with a semi-transparent wig. Iโm using Maxโs default scan line render and Poser 2014 is the version. I donโt have Fusion.
Actually, after looking closer, I'm wondering about your export method. Are you welding the seams? Also, there shouldn't be a substantial change in the geometry between the poser export and max import. Is your base model OK in Poser? I've attached a pic of my poser model and max model so detail can be seen
I tried importing a plain nude Victoria 4 figure and succeeded once in getting her in. After that, all I get is the same "invalid Normal Index" I've tried all variations of import settings with the same result. If I import any .obj file other than poser, there doesn't seem to be an issue. This is very frustrating.
Hi there
Here are my settings in 3DS MAX and they works without the single issue
Export from Poser
And simple render in Corona Render (Corona Alpha v6 ),on my spec this render took me just 150 passes/10 mins,there is visible noise which can be cleared after I would say after 50-100 more passes
In 3DS MAX don't use Poser preset,with this preset I've few problems in past
Hope this helps
Thanks,Jura
Just so the OP is aware: the Poser fusion plugins for Max, C4D and others are part of the Pro version. You have to download them separately and they have separate serials. Usually they are a released a month or two after Pro is released. IIRC, the new Fusion plugins for Pro 11 are now available for download.
Iโm trying to import M4 into 3ds max 2016. The figure is no problem, It just seems the textures donโt work out. That includes the hair transparency maps
