Wed, Nov 20, 12:36 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2024 Nov 19 6:44 am)
Subject: Cloth Room - Flag falls to ground - won't attach to flag pole.
fldrummerman ( ) posted Fri, 15 January 2016 at 9:45 AM · edited Tue, 19 November 2024 at 10:56 PM
I made a flag from the hi res square primitive, then made a flagpole. I parented the flag to the flag pole, but when I try to clothify the flag, it always falls to the ground. I changed the hierarchy so that the flag pole was above the flag, but it keeps falls. I tried to work with the constrained setting because that is where I think the answer is, but i never got the flag to stick to the pole. Any suggestions?
LaurieA ( ) posted Fri, 15 January 2016 at 9:54 AM
You need to go into the grouping tool and select a line of polygons down the side of the flag closest to the pole that you can set as "constrained" (remember to give that group of polys a name). That way those few will stay put and the rest of the flag will flop or flap like it's suppose to.
jennblake ( ) posted Fri, 15 January 2016 at 3:56 PM
😄 So nice to see everyone jumping in to help out in here. Thank you. 👍
saibabameuk ( ) posted Wed, 05 June 2024 at 6:11 AM
Any way to make the flag blow in the wind?
RedPhantom ( ) posted Wed, 05 June 2024 at 7:22 AM · edited Wed, 05 June 2024 at 7:22 AM
Site Admin
Use a wind force object
1 load your flag
2 load the wind force (under the objects menu)
3 Position the wind force to the direction you want your wind blowing.
4 You'll need to increase the range. Unless the flag is for ants, the default range is way too short
5 You'll probably also want to increase the amplitude. That's the strength of the wind
6 go into the cloth room and create a new simulation and clothify the flag
7 set the flag to collide with the wind
8 set and constraints as discussed above.
9 run simulation
10 adjust the amplitude
Here is what I got with my wind settings. I didn't have a good flag so I used the high-res square and choreographed the corners to simulate it being stuck in a pole.
I did need to add more frames to the simulation. This one didn't start flying until about frame 50. I did 300 frames and this frame is 291. If you need more detailed instructions for setting up the cloth room, let me know and I'll post them later today.
