Mon, Jan 6, 8:02 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 06 7:59 pm)
Subject: How do you import/convert Poser hair for use in Daz Studio 4.8?
philipd77 ( ) posted Thu, 28 January 2016 at 6:07 PM · edited Mon, 06 January 2025 at 7:52 PM
From what I've gathered, so long as the Poser hair product is not dynamic, supposedly it should work in Daz Studio, but I don't know if any special conversion or set up is necessary, particularly with the .hr2 files. Can anyone shed light on this, please?
Thanks,
philipd77
LaurieA ( ) posted Thu, 28 January 2016 at 6:42 PM · edited Thu, 28 January 2016 at 6:44 PM
Just link the Poser runtime where the hair resides inside the DS library and then load the hair as normal. It should work fine.
Tirenzi3D ( ) posted Thu, 28 January 2016 at 6:43 PM
You dont have to do anything other than load it via your directory in Studio.
philipd77 ( ) posted Thu, 28 January 2016 at 8:22 PM
LaurieA posted at 8:15PM Thu, 28 January 2016 - #4251861
Hi Laurie, thanks for the response. Could you please clarify what you mean by "linking the Poser runtime where the hair resides"? I'm new to Daz Studio and have been using DIM to install content from the Daz Store and manually unzipping Renderosity content inside my existing "Daz 3D Library ".
philipd77
markht ( ) posted Fri, 29 January 2016 at 12:49 AM
Your Daz 3D Library contains a runtime directory, and that is probably where you are installing it.
Content from Renderosity or any other non-DAZ store will never appear in smart content in DAZ Studio. (Much of the old V4/M4 content in the DAZ Store does not have Smart Content either). You need to find the content in the content panel. For Poser content, you need to look under "Poser Formats -> My DAZ 3D Library" if that is the library you have been putting it into. Under there you will find Figures, Hair, Poses, .... Usually the hair itself is under Figures or Hair and the color presets will be under Poses or sometime Materials. Most Hair material made for Poser will work in DAZ Studio, but a few hairs may have material that do not render like the promo images. Most Poser hair will not have Iray material, but the Poser material might well auto convert ok to Iray material. If the hair material uses Poser procedural shaders, it can render badly in DS, but I have not seen much of that.
Jules53757 ( ) posted Fri, 29 January 2016 at 2:13 AM
On the library pane just right click on Poser Formats > Add Runtime and then choose the respective runtime, that's all.
Ulli
philipd77 ( ) posted Fri, 29 January 2016 at 6:59 AM
markht posted at 6:57AM Fri, 29 January 2016 - #4251913
Thank you for the detailed explanation; I'll give this a go.
philipd77 ( ) posted Fri, 29 January 2016 at 7:02 AM
Jules53757 posted at 7:00AM Fri, 29 January 2016 - #4251923
Ok, thanks. ☺️
WendyLuvsCatz ( ) posted Mon, 08 February 2016 at 7:22 PM
you can convert Poser dynamic hair to a mesh too. looks like 3 minute noodles but still http://www.sharecg.com/v/27296
Dreaming Kitty Channel
Tom R. Toe
My ArtyFarty AI channel
philipd77 ( ) posted Mon, 08 February 2016 at 10:55 PM
wendyvainity posted at 10:55PM Mon, 08 February 2016 - #4253934
Thanks for the link!
