Mon, Dec 23, 9:29 AM CST
Subject: cant run PPRO 2010
santicor ( ) posted Fri, 29 January 2016 at 10:04 AM · edited Wed, 11 December 2024 at 3:05 PM
well first of all, regardless of the reason, I'm sorry to say I am still working in Poser PRO 2010. I am trying to use it on a different machine than I normally do, I downloaded it into an old machine which is running windows 7 -svc pack 1 - 64 bit
I don't see why it should not run, Ppro2010 on Windows 7....but i'm getting windows error " side by side configuration is incorrect" when I click the ppro2010 .exe
I don't know a lot about windows, compatibility, all that stuff, I just want to run Ppro 2010 on a different machine than usual, and I guess I am a little over my head
CAn someone tell me if its possible to run P Pro 2010 on W7 ? What is this error mean? and how can I work around it ?- last question- I went to my.smithmicro.com to look for some kind of updates to old poser versions, but that site kind of sucks you cant really successfully search around for old poser versions or updates or anything, does anyone know where in smithmicro land you can go to get an update? Thanks
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
 http://www.renderosity.com/homepage.php?page=3&userid=580115
LaurieA ( ) posted Fri, 29 January 2016 at 10:13 AM · edited Fri, 29 January 2016 at 10:14 AM
Did you install it to Program files? Try installing it OUTSIDE the program files folders and see how it runs. Might be UAC (User account control) that's causing your problems. It might also be a Windows 7 update that's causing it too, which would be unfortunate.
santicor ( ) posted Fri, 29 January 2016 at 10:25 AM
yeahhhhhhh....it doesn't run no matter where I try to run it from..... :-(
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
LaurieA ( ) posted Fri, 29 January 2016 at 12:35 PM · edited Fri, 29 January 2016 at 12:37 PM
I know W&W said that his copy of Poser 7, which did work fine in Windows 7, is no longer working and he thought it was a windows update. My guess is something to do with IE, but one never knows with Microshaft....it could be anything.
bagginsbill ( ) posted Fri, 29 January 2016 at 2:54 PM · edited Fri, 29 January 2016 at 2:54 PM
If you do not yet have SR 1.2, try here
"I went to my.smithmicro.com to look for some kind of updates to old poser versions, but that site kind of sucks you cant really successfully search around for old poser versions or updates or anything,"
But Google can. Let me Google that for you
Lobo3433 ( ) posted Fri, 29 January 2016 at 2:56 PM
Forum Moderator
Hello santicor
I had a similar problem a while back but I do have Poser Pro 2010 running on Windows 7 the problem came back to the Adobe Air application that is used in Poser Pro 2010 unless you have other more recent version of Poser Pro like 2012 or 2014 which will update Adobe Air when installed just uninstall Adobe Air and then reinstall Poser Pro 2010 and it will install the version it needs. Unless you need a latest version of Adobe Air for some other application then do not update it. Adobe Air in Poser Pro is needed so you can see your library. It is not compatible with current version of Adobe Air unless you have new versions of Poser Pro.
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
