Wed, Nov 20, 12:23 AM CST
Subject: Strange wireframe camera in the scene
jenay ( ) posted Fri, 12 February 2016 at 12:14 PM · edited Tue, 19 November 2024 at 11:49 PM
I opened an old cm2-File (from Poser5) and got a strange wireframe camera in the center of the scene (only in preview mode). It's not possible to select the camera or make it invisible. I tried with an empty scene - there is nothing, just the ground - and the camera. I couldn't find out what camera it is. Any ideas ?? I use Poser7.
EldritchCellar ( ) posted Fri, 12 February 2016 at 12:19 PM · edited Fri, 12 February 2016 at 12:24 PM
Can you click select it? Edit_ nevermind... I see that you can't. Humph. It's not showing as a prop or camera in the hierarchy? Try running the scene inventory script: list?
EldritchCellar ( ) posted Fri, 12 February 2016 at 12:36 PM
As an experiment you could save out another new .pz3 copy and see if the haunted camera still appears... ?
jenay ( ) posted Fri, 12 February 2016 at 12:58 PM
Screen inventory before loading the camera-set and after is the same.inventory01.png
jenay ( ) posted Fri, 12 February 2016 at 12:59 PM
I saved the scene as you proposed - and reopened it. The camera was no langer visible. strange ...
EldritchCellar ( ) posted Fri, 12 February 2016 at 1:04 PM
Buggy .cm2 file? If you open the .cm2 in a text editor it might reveal something. It basically just lists all scene cams and their settings, with active camera defined at the end of the file. Who knows?
jenay ( ) posted Fri, 12 February 2016 at 1:28 PM
I found a couple of cm2-Files that produce said effect. I inspected them with a text editor and found no issues. There are 14 cameras + 4 shadow-cams.
EldritchCellar ( ) posted Fri, 12 February 2016 at 2:17 PM
Shrugs. Well there is some version specific code in Poser that was shut off in later versions, you can still conjure up this code by changing the version # in the various Poser files. An actor visibility .pz2 is an example of this. If you felt like more experimentation you could take one of the glitchy .cm2 files and change the version # to 7 at the start of file. Apply the modified version # .cm2 and see if it "switches off" the unusual behavior of the file.
jenay ( ) posted Fri, 12 February 2016 at 2:53 PM
Thanks for helping. I give up with this issue. I think it's a Poser bug - and my old version well never be fixed.
BTW: I saw the version of that cm2-files is 7.2. I deleted all older files that caused the problem.
dadt ( ) posted Sat, 13 February 2016 at 3:00 AM
Simple answer-one of your cameras has "visible" selected in its properties.
