Sun, Feb 16, 7:35 PM CST
Subject: Poser 11 question???
MikeMoss ( ) posted Sat, 20 February 2016 at 11:19 PM · edited Sun, 16 February 2025 at 7:33 PM
Hi
This is kind of dumb but I can't figure it out. How do I show the ground plane without the grid on it?
The only way I can get it to come up now is with the grid lines.
Mike
If you shoot a mime, do you need a silencer?
basicwiz ( ) posted Sat, 20 February 2016 at 11:23 PM · edited Sat, 20 February 2016 at 11:23 PM
As far as I can tell, Mike, there is not a way. The new "ground" is no such thing. It is a complete enclosed environment. If all you want is a ground plane, make the default one invisible, then load the Hi-Res groundplane from the primitives folder. It will behave the way you are expecting it to. At least, this has been my solution.
wimvdb ( ) posted Sun, 21 February 2016 at 1:48 AM
If you want the old Poser 10 ground back as default, load the Poser 10 Workspace from Poser 11 Environments in the Scenes library. Then save it as preferred scene
Jules53757 ( ) posted Sun, 21 February 2016 at 2:26 AM
Just go to Display -> Guides -> Groundplane and uncheck it or use Ctrl + G to switch it on or off.
Ulli
vitachick ( ) posted Sun, 21 February 2016 at 4:37 AM
Next silly question..Had to reinstall Poser11...Since the search library still doesn't work, where is the primitives folder? Search just comes up with not found. When is SM going to fix this?? I really need the search unless you memorized all the vendor product names and what they are.
Win10  Poser 2014/Poser 11 Daz3D
Jules53757 ( ) posted Sun, 21 February 2016 at 4:43 AM
You'll find them here: Poser 11 ContentRuntimeLibrariesPropsPrimitives
In the Library pane it is Props > Poser 11 Content > Primitives
Ulli
raven ( ) posted Sun, 21 February 2016 at 5:12 AM
Make sure the construct is selected, go to Display->Object Style and select either smooth shaded or texture shaded. The ground of the construct will now be solid.
Boni ( ) posted Sun, 21 February 2016 at 6:43 AM
If you just want the grid not to show select the ground then go to Document Display at the left side of the pose window, Pick Element Display and select the smooth shaded.which in P11 is next to the last. I've saved that setting as my default. Never have to deal with the grid. But still have the construct as ground.DisplayMode.jpg
Boni
WandW ( ) posted Sun, 21 February 2016 at 7:20 AM · edited Sun, 21 February 2016 at 7:22 AM
To get Rid of the Grid, (if it wasn't so early I'd make a rap out of this. 😄 )
Select the ground under Props. Then from the Display Menu, Object Style>Texture Shaded
EDIT; Oops, I missed raven's post. I'll go back to rapping now... 😊
Boni ( ) posted Sun, 21 February 2016 at 7:33 AM
Keep in mind to render in Superfly the construct/ground is necessary to constrain the ray tracing in a contained area for more realistic renders avoid wasted render time.
Boni
bagginsbill ( ) posted Sun, 21 February 2016 at 8:52 AM · edited Sun, 21 February 2016 at 8:56 AM
Boni posted at 9:49AM Sun, 21 February 2016 - #4256434
Boni - this isn't true and you say it a lot. 1) It's not true because something else can be used instead, and 2) it's not true because there is no necessity to constrain rays.
bagginsbill ( ) posted Sun, 21 February 2016 at 8:54 AM
I just rendered this in 25 seconds with absolutely nothing else in the scene besides the car. One infinite light is the lighting. audi r8.png
MikeMoss ( ) posted Sun, 21 February 2016 at 3:48 PM · edited Sun, 21 February 2016 at 3:56 PM
Hi
Thanks for the responses everyone. I'll go and check it out now.
Mike
PS. Boni's solutions worked!!!
Boni ( ) posted Sun, 21 February 2016 at 4:01 PM
Ah, I was lead to believe this from assumptions based on threads I've read during the early weeks of Poser 11's release.
Boni
