Forum Moderators: RedPhantom
DocMatter posted at 10:27AM Thu, 25 February 2016 - #4257277
Does it have to be Poser 11? I have Poser Pro 2014.
Never mind... I just read the user guide. Damn!!
I checked it and it works in Poser Pro 2014 well.
Ulli
Jules53757 posted at 6:12AM Thu, 25 February 2016 - #4257341
You have to download the Genesis 3 Starter Essentials, this contains G3F and G3M.
Thanks, but searching for "starter essentials" turns up Genesis and Genesis 2, but not G3.
Levanah posted at 1:18PM Thu, 25 February 2016 - #4257357
anyone tried it with G3M...I end up with toon outline there all the time. Had the same issue with G3F but eventually was OK....just wonder...anyone?
Some postings above, I did it but the visimes and face morphs let the head explode.
Ulli
Well I got an error when I hit the UPDATE button: "Object reference not set to an instance of an object." When I close that dialog, the text in the program says Error and that's it. PP 11 64 bit, DS 4.8 64 bit. The first part that is done with DS saving out the G3F works fine. Poser loads that figure fine, so DSON is proven OK. Saving Figure out of PP 11 to new file name is fine, as it loads back into Poser ok. But running the Genesis3PoserSetup.exe gets the error. Oh, using external runtimes too. Any ideas folks?
My 66th Birthday PC Build (July 1, 2020) : named BadMoonRYZEN!, W10Pro x64, Octal Core RYZEN7 X3700 4.05 GHz, 64GB DDR4 RAM, GeForce RTX 3060 - 12GB GDDR6, PP2014, PP 11, P12, PS-CS4 Extended & Vue 2024.
McG.
Nevermind, I got it I got it! I messed up something in the saving process from DS. I deleted my mistakes and started fresh, following the Userguide PDF to the letter and it worked. Now I have a G3F loaded in PP 11 with Skin, morphs and posing. Time to go buy Fred Winklers Livia! McG.
McG.
ghostship2 posted at 8:09AM Thu, 25 February 2016 - #4257399
Does this work with the various morph packs that can be bought at DAZ?
The G3F I used has DAZ's Genesis 3 Head and Body morphs loaded. So, seems DSON Importer for Poser and the Save PCF's did the job right. The morphs did come into Poser with the G3F. Hm. For right now that seems to be the only way to get them in. Saving PCFs for various things might work, haven't tried that with morphs or character sets.
McG.
Hi All, I am so glad you are pleased with Willdiall's Genesis3PoserUpdater. He did a great job with it and I am so pleased he has given it to the community for free. Artistic freedom of choice is important and Genesis3 renders beautifully in Poser 11. Now let's create some great art. This image is rendered in Poser 11 Firefly using "Z Babylicious - Expressions for V7/G3F" available here at Renderosity..
Vendor expression sets now work.
Cheerio
lululee
lululee posted at 9:40AM Thu, 25 February 2016 - #4257406
Vendor expression sets now work. Cheerio
thank you both for an incredible job with this!
@ lululee; thank you for YOUR help getting this kit working!
@ the group; I have a question, there is a big dent at the center point where the jaw meets the neck, in Poser. Any idea on that one anyone?
McG.
lululee posted at 11:46AM Thu, 25 February 2016 - #4257431
McGrandpa, I'm not sure what causes that. Maybe Willdial knows. He'll stop in later as he is away from the computer right now. Cheerio lululee
Hi. It's a bug in the DSON Importer for Poser 1.2.0.12 - using an older version such as 1.1.3.50 does not produce the error
hi
someone pm'd and asked to see an image of the dson poser importer error, so here's a side by side of 1.1.3.50 and 1.2.0.12. It is known that 1.2.0.12 introduced some issues, distortion on the genesis ankle is the most common one.
Someone also asked if the Genesis 3 Poser Setup tool worked on the Genesis 3 Male - I didn't have any problems using it on G3m and the expressions and face morphs all worked and I didn't get any mesh explosions, it's probably set up for the female but don't tell g3m lol
here's G3M with the Angry expression dialled!!
A basic question? I do not have a file path called C:Data/ Production or a DSON Conversion folder. Do I have to create these if where? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
arrow1 posted at 6:30PM Thu, 25 February 2016 - #4257503
hi daz studio will create the DSON Conversions folder when you create the poser companion files
You can save the scene subset to any folder you want it doesn't have to be the C:Data/ Production folder - I made a new folder in my daz studio library called DSON Thingies and poser finds that folder from the poser companion files
We found the cause of the mesh explosion. It's due to the decimal separator issue. Some cultures use the comma (,) others use the period (.). I used Microsoft's recommend technique for convert to decimal value. Apparently, it doesn't work properly. (Insert Microsoft Here.) I hope to have an update soon.
Also, does anybody have some recommendations on how have the tool work for Macs? I'm a windows developer and all I have is an copy of Visual Studio 2008. The updater uses .NET Framework 3.5. Any suggestions would be helpful.
FYI. Don't bother posting news about the updater at DAZ. Someone made a post yesterday and now I can't find it.
Another basic question.I cannot find where the Genesis3 Poser Updater is to launch. I have installed it and I have searched python scripts etc and I cannot find it! I do have my Poser 11 Content on a H:/Drive called Poser 11 Content.Cheers
Razor42 posted at 6:20PM Thu, 25 February 2016 - #4257513
The mods merged a few threads regarding the utility, and moved them to the Poser Forum. Where it seems people are rather excited about it. :)
Cool. I'll go take a look.
All Okay.I found the Genesis 3 Poser Updater. Many thanks for all your help.Cheers
whah??
and i just bought my new quad core compy. and was tempted to bypass installing poser on it.
Now i might have to buy the new poser.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
For so long we have waited to be able to Render Gen3 in Poser & now it's here, Exclusively at Renderosity & it's FREE!
https://www.renderosity.com/render-daz-genesis-3-in-poser-cms-18144?&AID=408
Have a creative day!
My Lil' Store
