Wed, Feb 19, 3:36 PM CST
Forum Moderators: RedPhantom
Subject: Render DAZ Genesis 3 in Poser!!!!!! Now you can-FREE!
speculoos ( ) posted Fri, 26 February 2016 at 1:51 PM
Does someone else have the same problem once the G3F conversion is done?
Here is what happens when I apply a preset (1) or when I dial a pose control (2):
Any idea? :)
EAQS ( ) posted Fri, 26 February 2016 at 1:58 PM
Is there any way to turn off the bending limits in Poser all at once like it is done in DS? I tried with a text editor looking for all "forcelimits 1" and changing them to "0" and it does what it says but I get some weird results, I guess not all limits should be removed.
Jules53757 ( ) posted Fri, 26 February 2016 at 5:22 PM
Try to change your decimal seperator to dot instead of comma, for me it worked and now even G3M works well in Poser 11.
Ulli
arrow1 ( ) posted Fri, 26 February 2016 at 7:58 PM · edited Fri, 26 February 2016 at 7:58 PM
Online Now!
I am having problems with DSON Importer for Poser 1.2.0.12. I tried to install version 1.1.3.50 but the 1.2.0.12 shows up in the DSON in Poser Pro 11.Any suggestion as I have necks that are dented? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
McGrandpa ( ) posted Fri, 26 February 2016 at 10:13 PM
I've been told that is a little problem with DSON 1.2, and that till a fix happens to go back to 1.1.3.50 and it won't happen to G3F or to G2's ankle.
My 66th Birthday PC Build (July 1, 2020) :  named BadMoonRYZEN!, W10Pro x64, Octal Core RYZEN7 X3700 4.05 GHz, 64GB DDR4 RAM, GeForce RTX 3060 - 12GB GDDR6, PP2014, PP 11, P12, PS-CS4 Extended & Vue 2024.
McG.
arrow1 ( ) posted Fri, 26 February 2016 at 10:25 PM
Online Now!
I have just tried to install Poser Genesis 3 Updater on my Windows 10 Computer and I get this error.It installed fine on my Windows 7 machine.Any ideas. CheersG3 Poser Updater.jpg
arrow1 ( ) posted Fri, 26 February 2016 at 10:44 PM · edited Fri, 26 February 2016 at 10:44 PM
Online Now!
I have solved the problem with Windows 10.If anybody is having problems installing the Updater wind the Compatibility to a previous version of Windows. Cheers
infinity10 ( ) posted Fri, 26 February 2016 at 11:24 PM
#Poser #DSON #Genesis3 #CustomFaces #WillDial #ExpressionTransfer Some people have reported a strange protrusion in the neck area of the figure when using morphed Genesis3 faces in Poser.
This Japanese creator (who sells content at DAZ3D) has got it figured out :- http://enjoy-poser-imaging.air-nifty.com/blog/2016/02/render-daz-gene.html You will need to use a translation software to read the post.
Eternal Hobbyist
arrow1 ( ) posted Sat, 27 February 2016 at 12:50 AM
Online Now!
I have tried at least a dozen times to load DSON 1.1.3.50.Every time I check the version number it shows 1.2.Does anyone know how I can roll back my DSON version to 1.1 in Poser Pro 11? Cheers
Jules53757 ( ) posted Sat, 27 February 2016 at 1:57 AM
Whenn I installed the 1.1.3.50 I was asked to uninstall a previous version and th installer did it.
Ulli
speculoos ( ) posted Sat, 27 February 2016 at 2:52 AM
I have just found the answer to my question in this thread...:
We found the cause of the mesh explosion. It's due to the decimal separator issue. Some cultures use the comma (,) others use the period (.). I used Microsoft's recommend technique for convert to decimal value. Apparently, it doesn't work properly. (Insert Microsoft Here.) I hope to have an update soon.
Sorry, it escaped my attention...
willdial ( ) posted Sat, 27 February 2016 at 10:41 AM
I've released version 1.1 that should correct exploding head issue. You can re-download it from the Freestuff here
speculoos ( ) posted Sat, 27 February 2016 at 3:56 PM
Thank you very much for the update. I have installed it and I have reconverted the G3F file but the problem remains. The head still explodes when I dial a pose control...
I am not sure but perhaps that the update fixes the problem for other people...
Jules53757 ( ) posted Sat, 27 February 2016 at 6:05 PM
I installed it too but, I had to uninstall the previous version first and then to reinstall the new version and now ist works well with the comma as decemator.
Ulli
speculoos ( ) posted Sun, 28 February 2016 at 2:11 AM
I have uninstalled the previous version but as I said the new version did not solve the problem for me. I will try again to see if it works. Well I keep my fingers crossed... ;)
estherau ( ) posted Sun, 28 February 2016 at 5:20 AM
OK well I did it. I have the necky problem, but it works ie i can change expressions. I am on mac by the way. I just used winebottler which is a free utility and makes the program think that windows is installed to create a little stand alone utility. I chose xp and it worked fine I think. I mean I can dial the expressions. But there is a black line around the figure typical of genesis in poser. I thought it would make a native poser figure that didn't need dson anymore, as I find that these daz genesis figures with black lines work too slowly on my computer and I can't say, have a whole crowd of them in a scene. Love esther
MY ONLINE COMIC IS NOW LIVE
estherau ( ) posted Sun, 28 February 2016 at 5:22 AM
I thought it would make a true native poser figure. Love esther Screen Shot 2016-02-28 at 9.22.06 PM.png
speculoos ( ) posted Sun, 28 February 2016 at 7:55 AM · edited Sun, 28 February 2016 at 7:58 AM
I have tried again but for me the expressions do not work. I do not know what is happening because I have redone everything and I have removed all the files that I had exported and converted before. A mystery... I am going to post a request in the Willdial and Lululee G3F Poser converter forum...
AetherDream ( ) posted Sun, 28 February 2016 at 9:01 PM
Although I might never use this, it is nice to see that people who want to use G3F in Poser can now do it. Willdial and Lululee have done a very generous service for the community.
"People who attempt define what art is or is not, are not artists"---Luminescence
arrow1 ( ) posted Mon, 29 February 2016 at 7:09 PM
Online Now!
infinity10 posted at 12:08PM Tue, 01 March 2016 - #4257779
Does anyone understand what is being said about neck problem here> Cheers
willdial ( ) posted Mon, 29 February 2016 at 9:52 PM
arrow1 posted at 8:51PM Mon, 29 February 2016 - #4258381
See Here: https://www.renderosity.com/mod/forumpro/?thread_id=2900016
arrow1 ( ) posted Mon, 29 February 2016 at 11:59 PM
Online Now!
Another question if I may! When saving materials for example hair from DAZ Studio to Poser Do I save as IRAY or 3D Delight the material room? Cheers
lululee ( ) posted Tue, 01 March 2016 at 8:12 AM
  • Hi,
  • For anyone having the neck problem or invisible figures here is the correction:
  • I had some invisible clothing so I downloaded the earlier version of DSON from Daz that is * with the Genesis 2 figure essentials.
  • I used the DSON Importer for Poser DSON Importer for Poser BETA (Inactive)
  • It has to be the inactive one which is
  • DSON_Importer_for_Poser_1.1.3.49_Win64.exe 1.2 doesn't work as well.
  • I installed it in P11. It asked if I wanted to uninstall it and I said yes.
  • http://www.daz3d.com/dson-importer-for-poser
  • cheerio
  • lululee
lululee ( ) posted Tue, 01 March 2016 at 8:14 AM
Hi Arrow1, It is best to save the materials as 3Delight because the shader structure does not work in Poser. You can use EZSkin 3 to add the shader structure. Cheerio lululee
arrow1 ( ) posted Tue, 01 March 2016 at 5:59 PM
Online Now!
With DAZ 2 Starter Essentials do I have to download and install both DAZ and Poser versions or just the Poser Version? Cheers
arrow1 ( ) posted Tue, 01 March 2016 at 6:14 PM
Online Now!
I do not know how you are all installing the •DSON_Importer_for_Poser_1.1.3.49_Win64.exe. I have Installed Genesis 2 Starter Essentials and downloaded and installed the 1.1.Clicked uninstall then installed 1.1 version.1.2 still shows up in the DSON preferences. What am I doing wrong? Cheers
arrow1 ( ) posted Wed, 02 March 2016 at 12:10 AM
Online Now!
Many thanks everyone. I have managed to get DSON 1.1 installed finally. I had to uninstall Poser Pro 11 then reinstall it. I then installed the DSON for Poser 1.1.What I am finding is the library does not update straight away. Sometimes I have to close Poser 11 then reopen to get my DSON conversions to show. One last question.( I hope) Has anyone installed the expressions poses from DAZ Studio seeing they show up in the parameters? I was wondering if if there is any advantage if so do we save them as poses or FC2'S? Cheers
designer2101 ( ) posted Wed, 02 March 2016 at 1:44 PM
Hi I'm have some trouble with one section of the tut for this product. Can anyone tell me how to do this step. "Save G3 back to the Poser library under a different name" Thanks
FYI I'm using Poser 11 pro
hborre ( ) posted Wed, 02 March 2016 at 2:28 PM
@designer2101: I responded to you at the other thread.
designer2101 ( ) posted Wed, 02 March 2016 at 3:16 PM
Thank you found it
estherau ( ) posted Thu, 03 March 2016 at 5:26 PM
I haven't really tried this much, but does this figure work faster in poser than if we use normal genesis in poser eg genesis 2, or is it still using some python script everytime we pose and move the figure. eg crowd scenes in poser with lots of them?
Dim_Reaper ( ) posted Sat, 05 March 2016 at 2:04 AM
Just wanted to pop in and say a big "Thank you". I wanted to try this script when you first released it, but the main reason I don't use DS is because of the content interface. It has taken me several installs of DS and the content to actually get Genesis 3 working in DS. After that I had problems with an invisible Gen3 appearing in Poser. I finally had another go this morning and managed to get the base G3 figure into Poser.
After that, I installed the “Genesis 3 To Poser” utility by willdial and it worked instantly. Thank you very much.
i7 5960X, 32GB RAM, GTX 1080Ti, GTX 980 Ti, Windows 10 Professional.  Running Daz Studio 4.11, Poser 11, Vue Inf 7, Photoshop CS4
hborre ( ) posted Mon, 07 March 2016 at 7:30 AM · edited Mon, 07 March 2016 at 7:36 AM
estherau posted at 8:26AM Mon, 07 March 2016 - #4259134
If you are referring to the scene lag when moving or posing any Genesis, the solution is to change subdivision to zero. The default value for SubD is 1 when the figures are loaded through DSON. Change the value before performing any posing or scene changes.
Also realize, if you are loading multiple copies of the same figure, they do come in laden with whatever morph packages exist in DAZStudio. If you have dozens of packages loaded in Studio, you will have a rather larger figure file to deal with in Poser. At least with G3F in Poser, no other added morphs to DAZStudio will appear after generating a .cr2.
SAMS3D ( ) posted Mon, 07 March 2016 at 7:39 AM
Okay, someone asked me to post here, I followed all the instruction, downloaded the right DSON, but for some reason when I double click the file, everything loads except I can't see her? Very strange? Poser says she is there, but I can't see her?
hborre ( ) posted Mon, 07 March 2016 at 10:59 AM
IIRC, in another post, changing the subD to zero might make her reappear. I haven't had any visibility problems so I can't elaborate any further on this issue.
willdial ( ) posted Mon, 07 March 2016 at 8:15 PM
SAMS3D posted at 7:06PM Mon, 07 March 2016 - #4259677
Right now, our best theory is that Genesis 3, the Subscene Triax file, and the Poser Companion Files need to be installed into a Content/Runtime folder that Poser knows about.
hborre ( ) posted Tue, 08 March 2016 at 6:03 AM
Everything should be linked to each app. That is my understanding and I have that arrangement on my system.
KyReb ( ) posted Thu, 10 March 2016 at 4:43 PM · edited Thu, 10 March 2016 at 4:48 PM
Ditto here, A figure loads but every body part is set to ZERO, I tried changing things back to 100% but nothing appears
3DFineries ( ) posted Fri, 11 March 2016 at 7:31 AM
There's a Help Forum if you need it. 😉
Have a creative day!
My Lil' Store
infinity10 ( ) posted Mon, 14 March 2016 at 9:25 AM · edited Mon, 14 March 2016 at 9:25 AM
May I show you all that Genesis 3 Male is importable to Poser pro 11 with Head morphs working, and that mesh resolution and light setting needs tweaking to overcome the mesh grid lines showing in Poser Pro 11:-
Here is final poseable version, thanks to Willdial's utility:-
Here I show mesh grid lines appearing in render ( using Firefly and SSS ) :-
And this is my solution to remove the grid lines:-
Eternal Hobbyist
tchamberlain2 ( ) posted Sun, 03 April 2016 at 1:41 AM
So happy about G3 in Poser. Long anticipated. I like Daz and it has added to the 3d game a lot (especially with some of the best characters). However, Poser still has a lot of things Daz can not do. G3 inside Poser "dangerous." Now if some one can just get G3 in as a Cr2 working. But, maybe I'm asking too much...
thebert ( ) posted Mon, 04 April 2016 at 4:26 PM
I'm having the neck issue and I can't get DSON 1.1.3.x Beta to work with Poser 11. Any Help?
Thanks
The difference between stupidity and genius is that genius has its limits.
WandW ( ) posted Fri, 08 April 2016 at 11:30 AM · edited Fri, 08 April 2016 at 11:34 AM
thebert posted at 12:21PM Fri, 08 April 2016 - #4264180
Thanks
Are you using 1.1.3.49 (or 1.1.3.50; they appear to be the same)? The former should be in your DAZ product Library if you've had the Importer for a while; I don't know if latecomers get access to the Beta.
I install it using the downloaded installer rather than via DIM. Uninstall whatever Importer version is there, and make sure the Runtime\Python\addons\dson and the Runtime\Python\poserScripts\ScriptsMenu\DSON Support folders in your Poser 11 program folder are gone. Then install the importer to the Poser 11 program folder, and restart Poser.
thebert ( ) posted Fri, 08 April 2016 at 12:07 PM
Thanks, But I've worked around it. G3 Morph Fix.png I'd created a morph to fix it. again thanks thebert
emotionaldreams ( ) posted Fri, 06 May 2016 at 6:45 PM
Poser crashes when importing G3 with this thing
Kaine ( ) posted Wed, 01 June 2016 at 5:09 PM
hm i have another Problem with the G3F I can load her in Poser 11 Pro but only with 1-2 Morphs Most are missing.
And i can't find the Error.
DAZ Studio 4.9.2.70 Poser 11 Pro (SR4)
Kaine ( ) posted Wed, 01 June 2016 at 5:54 PM
Kaine posted at 12:52AM Thu, 02 June 2016 - #4271126
Ok, found the Error. The DAZ Connect Download is the Error Source. A New Manuell Install and no Problems :)
McGrandpa ( ) posted Wed, 08 June 2016 at 7:44 PM
Hi, so what version is the G3 Poser Importer now? Also, there are morphs for the face, expressions, that don't do much if anything at all. I bought, installed FW Livia G3F character, and loaded, applied the MATS got it out of DS 4.8 and into Poser Pro 11 SR2. I have no clothes in Poser for it, no poses. Any idea if this will eventually work "straight up" in Poser like Genesis 2 does? McG.
McG.
shotgung0d ( ) posted Mon, 13 June 2016 at 2:39 PM
PRO TIP!!!
Try learning to use DAZ|Studio.... Just sayin 😁
