Tue, Feb 18, 12:01 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Subject: Question about memory in Poser
Bristow13 ( ) posted Tue, 09 October 2001 at 10:47 AM ยท edited Sun, 09 February 2025 at 7:00 PM
Right i have the Daz Knee pads, when i go to put them on Michael i get an error it says something like i dont have enough meory and have tolet ore memory into Poser. ANY HELP PLEASE.
Marque ( ) posted Tue, 09 October 2001 at 11:09 AM
What operating system are you using? And can you please tell us exactly what it says? If it is telling you you are out of memory but gives you a directory with an .obj name at the end, it's poser's way of saying it can't find the obj that it needs to load the kneepads. It may have been put into a curiouslabs subdirectory instead of metacreations. Find out where it wants the obj to be by writing down the subdirectory it gives you, then find the obj by doing a search and put it where poser expects it to be. Hope this helps, all users get bit by this sooner or later. 8^) Now if you are on a Mac that's a different story as I guess you have to allocate memory, don't know, don't own a Mac. Marque
Bristow13 ( ) posted Tue, 09 October 2001 at 11:17 AM
Yes i dot have a MAC MY PC i a pentium 3 450mhz 64mb and Vodoo3 Graphics The first error says "Cannot open file Runtime/Geometries/rbtwhizCharacters/SkateGear/Kneepads.obj" Then it says "Cannot find Resource Runtime/Geometries/rbtwhizCharacters/SkateGear/Kneepads.obj" Then it says ! "you are out of memory" Please save your work and quit soon, you may also need to increase the amount of memory allocated in poser"
Bristow13 ( ) posted Tue, 09 October 2001 at 11:18 AM
I ment i dont have a MAC!!!!!!!!!!!!!111
brycetech ( ) posted Tue, 09 October 2001 at 11:24 AM
this means its not in the right place in the folder directory...check to make sure the obj file is where it belongs. this is a common error when a file is not installed properly, it has zippo to do with the memory allocations. BT
Marque ( ) posted Tue, 09 October 2001 at 11:27 AM
do a search for the file and when you find it put it in the subdirectory the error is telling you about. It will "fix" your problem. My guess is that you will find it in a CreativeLabs subdirectory. Marque
Bristow13 ( ) posted Tue, 09 October 2001 at 11:29 AM
Ok thanks guys. For all your help
Cheryle ( ) posted Tue, 09 October 2001 at 11:30 AM
if the obj IS in the correct geometries folder, try deleting the rsr. I have had models corrupt on me and when i delete the geometries RSR file for that particular model, that seems to fix it most of the time. hope this helps
LaurieA ( ) posted Tue, 09 October 2001 at 11:31 AM
If you don't know where your object should be, Poser is telling you: Runtime/Geometries/rbtwhizCharacters/SkateGear/Kneepads.obj Find the Kneepads.obj and place it there. If there is no rbtwhizCharacters folder in your Geometries folder, you will have to make one, but be sure you use the exact names and spellings as Poser is giving them to you. You will also have to make the other folder inside that folder (SkateGear). It should work fine for you then :) Laurie
LaurieA ( ) posted Tue, 09 October 2001 at 11:33 AM
Ack! All this cross-posting!....LOL. Laurie
