Mon, Feb 17, 7:46 PM CST
Forum Moderators: RedPhantom
Subject: DAZ's Generation 4 mil. figures and file placement
Boni ( ) posted Fri, 25 March 2016 at 4:27 PM · edited Mon, 20 January 2025 at 11:16 PM
I've had V4/M4/K4 through many versions of Poser. I notice that some morph dials don't seem to work with the models or more often their clothing in many situations. I assume it's placement of some key DAZ files in my runtimes that are causing this problem. I've read on this and am only becoming even more confused. I have these models themselves installed on older Poser versions but am using them in PP11. What files do I need to copy/paste to where in PP11 to alleviate this issue. I realize I should understand all this after all these years, but I'm getting more confused than informed it seems. Care to enlighten me? Make it simple guys. I'm smart, but I do get confused easily. (just ask bagginsbill!)
Boni
hborre ( ) posted Fri, 25 March 2016 at 5:23 PM
Online Now!
You might need to just reinitialize the batch files. I am working with V4/M4 installed into P7 runtime linked to Poser 11 Pro, no problems. Just make sure all your morph packages are installed to same V4/M4 base runtime.
basicwiz ( ) posted Fri, 25 March 2016 at 10:31 PM · edited Fri, 25 March 2016 at 10:31 PM
If you have saved copies of the figures with morphs installed, you may need to re-initialize, then load a fresh copy of the figure and re-add the morphs. I've had issues with this sometimes when going from one version of Poser to another.
WandW ( ) posted Sat, 26 March 2016 at 8:19 AM
Do a search of where you keep your runtimes for '!DAZ', and make sure there is only one set of files for each Gen 4 figure in among any Runtime/Libraries/!DAZ/ folders there are. Each figure will have a subfolder in this folder, eg, 'Runtime/Libraries/!DAZ/Victoria 4' and if there are duplicates, they need to be consolidated and the figures reinitialized.
There can also be a similar issue with Genesis 1 and 2 figures.. The issue in my case was multiple 'auto_adapted' folders generated by the DSON importer due to the Writable Runtime Folder in the Importer Preferences being set to different locations in PP 2014 and Poser 11...
