When using EZSkin3, assess how the original material zone nodes are arranged for your V4 character. The simpler, the better EZSkin3 will perform in giving you the best, optimal arrangement. If you find a convoluted array of nodes and plenty of dash line connections, begin eliminating the extra nodes and connect the relevant nodes to their proper connects, i.e., image map to diffuse, specular map to specular, transparency maps to transparent, etc. EZSkin3 will built upon the basics and give you an optimized material set up for each zone in your figure. You can tweak setting values in EZSkin to vary the way your skin texture responds to light to give you something more to your liking.
Eagle_hawke posted at 4:12AM Mon, 18 April 2016 - #4264767
Ok it looks like that's working thank you. I'll post the final results when it's done rendering. Tho it may take a bit. Not too thrilled that I have to use this now anytime I want to use a V4 or M4 model but I guess it is what it is. Thank you for the help.
You don't HAVE TO use EZSkin anytime you use V4 or M4, the skin rendering problem you got there is not related to V4 or M4 in particular, but to the nodes used in the skin settings. So you can change the nodes yourself too. SuperFly tries to render correctly the materials made for FireFly, but as we made a lot of tricks to have correct skin with FireFly, it fails with SuperFly as this render engine doesn't needs complicated node trees to make beauty.
So it's not related at all to specific figures, but to bad nodes connections (good for FF, but bad for SF) :)
Ok I have this weird problem going on maybe someone might have an answer for me. I have had Poser 11 for a few months and been very happy with it but only a few days ago I decided to be brave and play with the Superfly Render Engine. So I watched the Tutorial and the my first render was a disaster....as was the second, third fourth, fifth. I have watched all the tutorial I could find and read help files, and I can find nothing to explain this. Everything in the Render Area Renders beautifully, EXCEPT Any V4/M4 Figure I put in there. I have used several different Character MAT files and they all do the same thing.
I have gone through every Superfly Preset and played with all their setting I even matched my setting with the Tutorials. Nothing seems to be working. Tell me this is not a compatablity issue with Superfly and M4/V4 Models please!
Thanks in advance for the help
