Thu, Jan 9, 7:27 AM CST
Subject: POLL: What Poser Version Do You Use?
SpookieLilOne ( ) posted Mon, 18 April 2016 at 10:54 PM · edited Wed, 08 January 2025 at 10:39 PM
If you would kindly follow the link :)
https://www.renderosity.com/which-version-of-poser-do-you-own--cms-18240
*~*Jamie*~*
SpookieLilOne's Store
SpookieLilOne's FreeStuff
SpookieLilOne's Gallery
"Life is just a dream on the way to death." ~The Crow: City of Angels
shvrdavid ( ) posted Tue, 19 April 2016 at 6:29 AM
I have multiple versions installed, and the poll does not allow you to select more than one.
3DFineries ( ) posted Tue, 19 April 2016 at 7:07 AM
Done! I too have more than one version. :) Poser 6, Poser Pro 2012, & Poser Pro 2014 so I just voted for the highest version.
Have a creative day!
My Lil' Store
Sa_raneth ( ) posted Tue, 19 April 2016 at 10:56 AM
have more than one version like 9 and 10 use both
MistyLaraCarrara ( ) posted Thu, 21 April 2016 at 8:26 AM
i have 7 and pp12 on my old pc.
haven't decided if i want to install on my new pc.
looked at the new pp version, but for a couple hundred more i could get Lightwave
parkdalegardener ( ) posted Fri, 22 April 2016 at 6:28 AM
Useless poll as many of us run numerous versions. Everyone who upgrades Poser ends up with multiple versions. What they had before the upgrade and what you have afterward. I run 7 versions over 4 different computers and 3 different operating systems as I like to be able to trouble shoot stuff and write tutorials that are of use to folk. This poll is not going to give you any real info about a lot of Poser users as you can see from the comments above.
ssgbryan ( ) posted Tue, 26 April 2016 at 10:31 AM
I'm pretty sure that what they were going for was which version are you using.
I am just hopeful that seeing 80% of folks on Poser 9 or later will get vendors to get up off their asses and ditch Poser 7 and the Poser 7 way of doing things. My spending here has dropped about 90% because I am tired of having to spend so much time converting new products purchased here to Poser 9 or later standards.
wolf359 ( ) posted Wed, 27 April 2016 at 10:05 AM · edited Wed, 27 April 2016 at 10:07 AM
"I am just hopeful that seeing 80% of folks on Poser 9 or later will get vendors to get up off their asses and ditch Poser 7 and the Poser 7 way of doing things."
This will never happen without some governing authority enforcing a top down uniform standard as to what will be allowed in the marketplace.
Poser's/SM's business model ( ie charge hundreds of dollars for the program itself) causes many users to forego upgrading.
Therefore the marketplace here at renderosity cannot reasonably force content makers to abandon older formats.
"looked at the new pp version, but for a couple hundred more i could get Lightwave"
If your plan going forward is to create CG without major involvment of poser content then yes Lightwave may be a good option.
uggh!!.. this forum software is such rubbish!!!<<<
My website
EboMarconi ( ) posted Thu, 28 April 2016 at 10:11 PM · edited Thu, 28 April 2016 at 10:12 PM
I am using Poser Pro 2010 and Lightwave 9.6 I'm currently working on some new stuff to sell and if I can make enough money then they will both be upgraded to the latest versions. But for now these are working well enough. Lots of strange little quirks in getting props modeled just right for Poser though. I figure there always will be.
AmbientShade ( ) posted Fri, 29 April 2016 at 11:59 AM · edited Fri, 29 April 2016 at 12:01 PM
parkdalegardener posted at 12:51PM Fri, 29 April 2016 - #4266569
Not useless at all. The question was not "how many poser versions do you own", but instead "What is the latest version of Poser that you own?"
How many versions is irrelevant since most content for older versions is still compatible with newer versions.
This helps content artists get a better sense of what the market would be like for specific types of content with features that only exist in the later versions. It also helps put to rest the false notion that "most" people are still stuck on P7 or earlier.
It's definitely helped me reach a decision about certain things I've been planning, so I'm glad they put this poll up.
bopperthijs ( ) posted Sun, 15 May 2016 at 3:33 PM
Poserpro11 and poserpro 2014. I still use 2014, until I have poserpro 11 setup like I want it and it's stable enough.
