Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 5:20 pm)
Hi. The DSON option that shows information to a user as an item loads can cause problems with the Poser library and makes it unusable for some people.
It is recommended to disable this option for those who have library issues.
On the Poser Menu Bar - Mouse click on Scripts
select - DSON Support
select - Importer Preferences
The Preference box will open
Untick - Show Progress On Load
Close the Preference box using the X (Top Right of Box)
vitachick posted at 11:38PM Mon, 25 April 2016 - #4266840
undock content library? Thought that was only available in Poser2014.. Do tell how to show as external..Like it much better
It's OT, but... you can dock or undock the Library panel just as you can any other panel in the Poser UI - perhaps this is not what you mean. You can also run the Library in a separate browser window, as I do (on a second screen) - is this what you are asking about? (By the way, I don't have any DSON importer problems when running the Library like this).
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Do you have the latest SR installed? I had this issue, and I believe this was fixed in SR1, IIRC...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi folks... Here's the rub. I'm trying to use daz figures with DSON importer but the program just hangs after loading one, say Lee 6..I can move the figure, but I'm unable to use the content window...it loads fine, but after that it just hangs there...Any ideas? Thanks a lot.
