Mon, Feb 10, 7:20 PM CST
Subject: Poser 7 - Deleting Blank Folders
GBREAL ( ) posted Tue, 07 June 2016 at 4:02 PM · edited Mon, 10 February 2025 at 7:07 PM
Hello
I installed Poser 7 after not using it for about a year. I am using Windows 7. I notice that the library is showing folders that have been deleted. (See Attached)
The folders "AntFarm" and "DAZ 3 Aiko" should be deleted because they are not in my directory. (See Attached)
I tried uninstalling the program and reinstalled it but it hasn't changed anything.
Anyone know how to fix this?
Boni ( ) posted Tue, 07 June 2016 at 5:35 PM
Silly question. Did you delete the folders before or after launching Poser. If you deleted them AFTER loading poser you may have to re-start Poser for it to take effect. Also ... an I'm not sure of this P7 is one version I never had. if you highlight a folder you want to "delete" in the library, there may be (it is this way in the versions I have) a minus - sign. that could also delete the folder from within Poser.
Boni
hborre ( ) posted Tue, 07 June 2016 at 8:36 PM
Online Now!
Waitaminute, there is no convenient way to delete folders from within Poser, even in Poser 11 Pro. I can remove files, but not folders.
RobZhena ( ) posted Wed, 08 June 2016 at 5:10 AM
Online Now!
hborre posted at 6:09AM Wed, 08 June 2016 - #4271788
That's the sad fact. And if you do it manually on your desk top, it triggers a big reindexing in my experience.
Boni ( ) posted Wed, 08 June 2016 at 6:24 AM
It will be later today, But I will look into this. Rob, perhaps we can report this.
Boni
A_Sunbeam ( ) posted Wed, 08 June 2016 at 8:24 AM
You could try deleting the Poser preference file - and rebooting. Might work.
MarianneR ( ) posted Wed, 08 June 2016 at 12:38 PM
Are you sure that you are looking in the correct folder? What is the path used in the first screenshot? Is it the same as in the second: ..../Poser 7: downloads:Runtime: etc etc
hborre ( ) posted Wed, 08 June 2016 at 1:59 PM
Online Now!
What I'm interpreting from the screencaps is Poser 7 has been installed into Program Files under Window 7, a definite no-no with OS Vista and above. I am also imagining that content is/was installed into the primary download runtime. Now, with current Win OS's after Vista, UAC will restrict any read/write activity into Program Files folder, and, where Poser is concerned, any content installed into that folder will be placed into a virtual location. I don't remember where that location is, but this issue might be related.
GBREAL ( ) posted Wed, 08 June 2016 at 2:26 PM
A_Sunbeam posted at 2:20PM Wed, 08 June 2016 - #4271822
Yup tried this. I even uninstalled and reinstalled the program and the folders are still showing up.
MarianneR posted at 2:26PM Wed, 08 June 2016 - #4271841
Yes the folder is correct.
GBREAL ( ) posted Wed, 08 June 2016 at 2:27 PM
hborre posted at 2:27PM Wed, 08 June 2016 - #4271848
Yes Poser has been installed in the (x86) Program files folder. Is that bad?
hborre ( ) posted Wed, 08 June 2016 at 3:08 PM
Online Now!
No, if the Poser program is installed without content; yes, if content is loaded into the same parent runtime. Window UAC prevents write backs to files in that location, and shutting down UAC will leave your system vulnerable to malware attacks. In addition, you will have problems accessing content files, and saving character, props, poses and textures. And if anything manages to get saved back to the Poser Library, you will not find it in the Poser runtimes but rather in a virtual location, For that reason, the most current versions of Poser will install content in a shared folder location away from Program Files.
hborre ( ) posted Wed, 08 June 2016 at 3:18 PM · edited Wed, 08 June 2016 at 3:19 PM
Online Now!
C:Users/admin/AppData/Local/VirtualStore/Program Files
Those folders will most likely still be in the above location.
IsaoShi ( ) posted Wed, 08 June 2016 at 3:29 PM · edited Wed, 08 June 2016 at 3:36 PM
My bet is that MarianneR is on the right track. Can you categorically confirm that in the Poser screenshot you selected the Downloads library, and not the main Poser library?
If so, try hitting the 'up one level' button, then closing and re-opening Poser.
Edit: also, check (in Windows Explorer) what folders are present in the path: ... \ Poser 7 \ runtime \ libraries \ character
MarianneR ( ) posted Wed, 08 June 2016 at 4:12 PM
Reading hborre's reply I think that they are right, and my guess was wrong. It doesn't work when the content is installed in one of the C:/program files folders in Windows 7. I don't remember if the Poser 7 installer will allow you to install the program itself and the contents in different folders. One easy way to solve the problem is to install the lot outside of the program folders. My Poser program is installed to C:/Poser
