The Poser 11 preferences file is in your user Application Support folder:-
Users / {username} / Library / Application Support / Poser (or Poser Pro) / 11 / Poser Prefs
It should be there for earlier versions too.
Note that the Library folder might be hidden, depending on your version of OS X. I have unhidden mine.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
from your desktop hit: Command + Shift + G
for poser pro 11 (what I have) paste: ~/Library/Application Support/Poser Pro/11/
and hit enter
For Poser pro 2014: ~/Library/Application Support/Poser Pro/10/
I dont have it but my guess for poser pro 2012: ~/Library/Application Support/Poser Pro/9/
And maybe poser 11: ~/Library/Application Support/Poser/11/
Let me know if you find it. If not I will explain how to show hidden files and folders
Well I found files for 10,11,11_201603300905, and 11_201605242056 Inside I find a bunch of stuff but I'm assuming poser prefs is the file I want , is that correct? Do I remove this file from each of these folders? for the PP2012 folder I find /poser pro/9/ but no prefs file for poser 9 For m own Info how do you show hidden files and folders? Thanks
Navigate to /Applications/Utilities and doible-click on Terminal
then paste this: defaults write com.apple.finder AppleShowAllFiles YES; killall Finder /System/Library/CoreServices/Finder.app
hit enter
To hide paste this: defaults write com.apple.finder AppleShowAllFiles NO; killall Finder /System/Library/CoreServices/Finder.app
hit enter
No need to use Terminal, there's a much easier way:-
Open a Finder window, hit Command+J (Show View Options), and tick the option: Show Library Folder.
what I should be."
Murakami)
I'm sure this has come up before but my search didn't help. I'm running both Poser 11 (latest version) and Pro 2012. Both have the same problem and I'm convinced it has something to do with the preferences. Problem is I can't find them for either app. I've refer the SM articles but they aren't where they say they should be. Perhaps if I knew the exact title for this files I could do a search but as of now i am at loss. . . ideas?
