Wed, Dec 25, 12:33 PM CST
Subject: Add trans map, without over ridding texture.... HOW??
DigitalDreamsDS ( ) posted Wed, 06 July 2016 at 1:52 AM · edited Wed, 25 December 2024 at 11:47 AM
I want to make a transparency mat that can be used with several texture options. How do I do this without getting rid of the existing texture? I don't want to have a bajillion mat files lol
Boni ( ) posted Wed, 06 July 2016 at 7:09 AM
What version of Poser are you using? P11 has a layers feature that could save time and energy ... but there are ways in older versions of Poser as well.
Boni
tonyvilters ( ) posted Wed, 06 July 2016 at 8:48 AM · edited Wed, 06 July 2016 at 8:52 AM
If you want to use multiple transmap texture files on a single Material zone.
Use a Blender node. From Transparency, create a Blender node
  • Connect Transmap 1 to Input 1 of the Blender node
  • Connect Transmap 2 to input 2 of the Blender node
  • Blender set to 0.000 and Input 1 will be used for transparency
  • Blender set to 1.000 and Input 2 will be used for transparency
  • Setting the Blender between 0.000 and 1.000 will mix Input 2 with Input 1
Hope this helps? Euh, load Transmaps at GC 1.000
Poser11 has layered texture possibilities, but only for the SuperFly render engine.
Boni ( ) posted Wed, 06 July 2016 at 2:19 PM
👍 , thanks Tony. You Rock!!
Boni
DigitalDreamsDS ( ) posted Thu, 07 July 2016 at 9:05 AM
Tony, I'm sorry I think you misunderstood. For example, I have a pair of gloves that have a texture applied, but I want to have a material setting that will apply a trans without overriding the existing material. How do I save this mat file? Do I need to edit the mat file in note pad?
Boni ( ) posted Thu, 07 July 2016 at 3:09 PM
Ah, I've struggled with this problem as well ... again, P11 solves this ... but if you don't have P11, we need help.
Boni
3DFineries ( ) posted Sat, 09 July 2016 at 6:00 AM
You can just plug in your map to the transparency node and set value to 1. Not sure how you can save it so you can reuse it without overriding though. Usually, you will just click the + sign in the material room and save the whole thing or just one node, but when you load that mat again, it is going to override everything there. Check out ArtBees Missing Poser Manuals as it may help or wait until one of the gurus comes along.
Have a creative day!
My Lil' Store
