Wed, Feb 26, 5:14 PM CST
Forum Moderators: RedPhantom
Subject: Sketch Render in Poser
Digitell ( ) posted Fri, 15 July 2016 at 1:15 PM · edited Wed, 26 February 2025 at 5:09 PM
Forum Coordinator
I have been trying out the Sketch Render feature in Poser. I have a problem with a black line that runs down the right side of image and the sketch seems to turn lighter too. I have tried this on both Poser Pro 2014 and Poser 11 and both do the same things. I have tried different images and get that same result. Is anyone familiar with the Sketch Render and can tell me why it does this? I have attached a couple images to show what it does. Any help would be greatly appreciated! Thanks! sketchbg_SM.jpg zep_Sm.jpg
quietrob ( ) posted Fri, 15 July 2016 at 11:13 PM
I'm not getting that when I use the Sketch Render. Does it do this on every single sketch? Have you tried resetting back to defaults? I used the same dimensions and format as you did. Below is what I got.
infinity10 ( ) posted Sat, 16 July 2016 at 1:39 AM
I suspect it is a lighting -related issue. Poser will do calculations, but when it's too close to some value of lighting, it just makes a cut between a darker and a brighter area, and if there're outlines involved, you get a line.
Eternal Hobbyist
Boni ( ) posted Sat, 16 July 2016 at 6:25 AM
That is a curious oddity. I can only guess that the camera or lighting settings may be at fault and the sketch render is reading a "too close" edge feature. This is a wild guess mind you.
Boni
Digitell ( ) posted Sat, 16 July 2016 at 7:30 AM
Forum Coordinator
HI guys..thanks for the replies. I have tried different lights and get the same thing so I don't have a clue. I will keep trying with different light situations and see if that is the culprit. Thanks so much for trying to help!
Boni ( ) posted Sat, 16 July 2016 at 8:27 AM
Here is a variation of my first post. Perhaps there is a camera or light "object" that would normally not render that is partly in the scene but in Sketch mode does ... like the odd render that transparencies and strandbased hair has. Just throwing ideas at you to try.
Boni
Digitell ( ) posted Sat, 16 July 2016 at 8:33 AM
Forum Coordinator
You are right Boni, that could very well be it..I am trying different lighting options but I should also look at the camera..It make be showing up ..perhaps I could make it invisible. Thanks so much! 👍
Digitell ( ) posted Sat, 16 July 2016 at 9:20 AM · edited Sat, 16 July 2016 at 9:21 AM
Forum Coordinator
Well I did see I had my Main Camera visible so thought that may be the culprit. So I made it invisible and deleted all my lights and added just 1 spot light and pulled it back so my whole figure would have light. I this time randomly chose the WoodCut_DA setting for sketch and this is what I got..it cut off that same side completely. "Scratches Head"...what a mystery!Render 2.jpg
Rendered in Poser Pro 2014.
quietrob ( ) posted Sat, 16 July 2016 at 1:32 PM
Just curious as we spray to all fields.
In your render dimensions, Are you using match the preview window or to exact specifications? Is there a difference when you do?
IsaoShi ( ) posted Sat, 16 July 2016 at 3:23 PM
Does this only happen with a sketch render? Did you already try rendering the same scenes with FF/SF?
Boni ( ) posted Sun, 17 July 2016 at 7:56 AM
Could you do a little experiment for me? take the top cam and look over the scene, make all lights and cameras visible ... and see if you need to move one out of the camera rang of the main camera (or what camera you are using).
Boni
Digitell ( ) posted Sun, 17 July 2016 at 10:44 AM
Forum Coordinator
Hi Guys,
@Quiotrob, I am using :Render to exact resolution ( i need specific size and resolution) I have not tried using another setting but will do to see what happens! Thank you for suggesting this! :)
@Isaoshi, Yes it only happens in sketch. I did regular render in FireFly and it turned out nice. I am wanting to put the sketch on top of the regular scene and try different blends in Photoshop. Thank you for posting..this has been a delima! :)
@ Boni, OK! Will give this a shot to see what happens!
Thank you guys for reaching out and trying to help..tis such an oddity! :)
Digitell ( ) posted Sun, 17 July 2016 at 11:03 AM
Forum Coordinator
@Boni, I did the top camera view making all cameras and lights visible. I saw nothing that would be obstructing the view. I made all cameras and lights invisible again and tried the woodcut sketch. Still same result. Next going to try changing the dimensions as Quietrob suggested.
Digitell ( ) posted Sun, 17 July 2016 at 11:14 AM
Forum Coordinator
OK, I changed the resolution to "fit in preview window". No Line and it rendered the whole scene as should..however..I need the resolution to be high quality as in the original render with the line down it. I am posting both so you can see the difference. At this point, I am ready to give up on it and move on..I do not have a clue why I am getting that line down the right. There is nothing in the scene that should cause this. I realize the problem is in the chair and not in the Program hehehe..but obviously it is over my head! 😅
ghostship2 ( ) posted Tue, 19 July 2016 at 10:14 PM
in another thread here was a discussion about memory and using a separate process for rendering (edit menu, general preferences, render tab) make sure this is checked and try another render. Who knows?
RorrKonn ( ) posted Wed, 20 July 2016 at 2:51 AM
maybe render in a square 3000by3000 ,1000by1000 etc etc. crop in photoshop :)
Tron1138 ( ) posted Wed, 20 July 2016 at 5:14 AM
OP, did you make these models yourself? If so what program did you use?
Digitell ( ) posted Wed, 20 July 2016 at 7:05 AM
Forum Coordinator
Hi ghostship2 and RorrKonn, Thank you! I will try these methods and see what happens. Not thought of either of these..thank you! :)
Tron1138, The model I bought here at Renderosity, 1971 is the vendor and here is a link: HeavenlyZeppelin
Tron1138 ( ) posted Wed, 20 July 2016 at 7:40 AM · edited Wed, 20 July 2016 at 7:40 AM
Thanks digitell.
raven ( ) posted Wed, 20 July 2016 at 8:52 AM
Is the preview window the same ratio as the final render size? I ask because as it works at the preview screen size, try setting the preview to the same ratio as the finished size you want. Then try and render it at the required size.
