Mon, Jan 6, 10:44 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: chamfer option
mrsparky ( ) posted Mon, 11 July 2016 at 7:19 PM ยท edited Mon, 06 January 2025 at 10:35 PM
Does anyone know where in Carrara 6 pro is the chamfer menu ?
TIA
MarkBremmer ( ) posted Tue, 12 July 2016 at 6:09 PM
It's called a "Fillet" in C6. You'll find it in the top icon row once in the Vertex room. A best practice is to select the edges you want to Chamfer before selecting the tool. Amount and smoothness of the chamfer can be adjusted in the tools pallet dynamically before hitting enter/return on the keyboard.
mrsparky ( ) posted Sat, 16 July 2016 at 10:34 PM
Thanks for that - this is what I've found so far - is this the correct way to do it?
Plus what do the radius and range options do?
Kixum ( ) posted Sun, 17 July 2016 at 12:02 AM
You can select a single vertex to chamfer or many vertices. If you select a face, all the vertices are selected.
The radius is the size of the chamfer and the range is the number of added vertices that will be added to create the chamfer. You can adjust the settings and then press the return key to finish the action. Before you hit enter, you can change settings and watch what the changes will do to the model.
-Kix
Kixum ( ) posted Sun, 17 July 2016 at 12:03 AM
I guess I should say, if you select a face, all the vertices touching that face will be chamfered.
-Kix
MarkBremmer ( ) posted Sun, 17 July 2016 at 9:43 AM
@MrSparky, I'd suggest playing with the options to find out. ;-)
de3an ( ) posted Sun, 17 July 2016 at 1:37 PM
Filleted edges that intersect must all be selected before choosing the Fillet tool so that the intersecting corners are calculated correctly. Selecting edges individually with the tool will lead to bad corner geometry.
mrsparky ( ) posted Sun, 17 July 2016 at 9:14 PM
Thanks everyone - playing and finding out what you're saying can happen - but overall think I've cracked this one - so thanks again.
