Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Visit the Carrara Gallery here.
It's called a "Fillet" in C6. You'll find it in the top icon row once in the Vertex room. A best practice is to select the edges you want to Chamfer before selecting the tool. Amount and smoothness of the chamfer can be adjusted in the tools pallet dynamically before hitting enter/return on the keyboard.
You can select a single vertex to chamfer or many vertices. If you select a face, all the vertices are selected.
The radius is the size of the chamfer and the range is the number of added vertices that will be added to create the chamfer. You can adjust the settings and then press the return key to finish the action. Before you hit enter, you can change settings and watch what the changes will do to the model.
-Kix
Does anyone know where in Carrara 6 pro is the chamfer menu ?
TIA
