Fri, Jan 24, 6:30 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: No Collisions in Bullet Physics
Iuvenis_Scriptor ( ) posted Sat, 23 July 2016 at 12:14 AM · edited Thu, 09 January 2025 at 8:34 AM
I'm toying around with Bullet Physics in Poser Pro 11, but I cannot get anything to collide with anything else. In a simple scene, I have a high-res sphere underneath a cloth plane. The ball is Choreographed and the plane is Soft Dynamic, but the latter still just goes straight through the former and lands on the Ground. I've tried enabling collision detection on both props, but that had no effect. Does anyone know what I could be doing wrong?
RedPhantom ( ) posted Sat, 23 July 2016 at 5:57 AM
Site Admin
I've only done bullet physics once so I really can advise but I followed the tutorial here https://www.renderosity.com/mod/tutorial_premium/?page=info&tutorial=17 and was able to get collisions. Maybe it can help you too.
Cage ( ) posted Sun, 24 July 2016 at 3:23 PM
Simulated objects will only collide if they are part of the same simulation. Set up a simulation, set the cloth plane as softbody (third tab), then set up the ball as part of the simulation in either the first or second tabs.
Bullet uses convex hulls of simulated objects, for speed while calculating collisions. If the objects fail to interact, the problem might relate to the convex hulls. You can create and study samples of the convex hulls, using the... Object menu? Up on the file menu bar, one of the headings will list "Create convex hull" on its pull-down menu. Clicking that option will create an un-transformed (no translations, rotations, or scaling) copy of the convex hull for the currently selected actor, showing Poser's internal representation of an object for Bullet's purposes. Unfortunately, I'm not sure what remedy to suggest if your simulation problems result from failed convex hull collisions....
Anthanasius ( ) posted Mon, 25 July 2016 at 1:40 PM
Hi !
Already see this video but dont help, how to use a dress on a character with bullet ?
Génération mobiles Le Forum / Le Site
