Sun, Jan 5, 4:44 AM CST
Subject: Poser2Blender2Poser, new series.
tonyvilters ( ) posted Thu, 28 July 2016 at 7:13 PM ยท edited Sun, 05 January 2025 at 4:38 AM
First of the new video series uploaded.
Poser2Blender2Poser 1 : The correct Poser and Blender Export -Import settings to get Poser groups and figures in Blender to create Morphs.
Poser2Blender2Poser 1 ; The correct Export-Import options
Next in the new series will be improved video's on how to detail the meshes, get some clothing over them, and general finetuning to get the most out of the Poser-Blender combination.
Have fun using the Poser - Blender tools. Best regards, Tony
EarthCrone ( ) posted Fri, 29 July 2016 at 8:52 AM
Thank you for this.
"Imagination is more important than knowledge" Albert Einstein
Kazam561 ( ) posted Fri, 29 July 2016 at 9:16 AM
Thank you very much Tony!
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
FVerbaas ( ) posted Sat, 30 July 2016 at 12:22 PM
Forum Coordinator
Good tutorial presented at the right pace with the proper amount of explanation. You are a teacher by profession?
tonyvilters ( ) posted Sun, 31 July 2016 at 3:30 PM
New video uploaded in this series. ( Ha, no FVerbaas, no teacher. Retired Air Force Capt-Commander)
Poser2Blender2Poser 2: Detailing Poser meshes using FBM and HD Morphs created in Blender.
In this second video, we will "detail" the Poser11 Pauline figure using a FBM created in Blender. Then finetune the mesh detail by projecting a High Definition Morph into the figure using the Fitting Morph brush tool.
The result is an improved Pauline using a FBM and then further enhanced with a HD Morph projection. For a close-up render, the end user can leave both dials active. When the figure is far away from the camera, the end user can turn the level of detail down by removing the SubD if required to save memory.
Best regards, Tony
quietrob ( ) posted Sun, 07 August 2016 at 8:03 PM
This is so needed! Thanks Tony!
tonyvilters ( ) posted Wed, 10 August 2016 at 11:20 AM
Third video uploaded in this series.
How ALL Poser versions that have the morph brush can work with FBM and HD morphs.
ALL Poser versions that have the Morph Brush can use FBM and HD Morphs.
tonyvilters ( ) posted Sat, 13 August 2016 at 5:14 AM
Video number 4 in this series; Why do you have to delete and replace the object files Poser saves for you.
Why do you have to delete and replace the Poser saved obj files?
