Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
New video uploaded in this series. ( Ha, no FVerbaas, no teacher. Retired Air Force Capt-Commander)
Poser2Blender2Poser 2: Detailing Poser meshes using FBM and HD Morphs created in Blender.
In this second video, we will "detail" the Poser11 Pauline figure using a FBM created in Blender. Then finetune the mesh detail by projecting a High Definition Morph into the figure using the Fitting Morph brush tool.
The result is an improved Pauline using a FBM and then further enhanced with a HD Morph projection. For a close-up render, the end user can leave both dials active. When the figure is far away from the camera, the end user can turn the level of detail down by removing the SubD if required to save memory.
Best regards, Tony
Third video uploaded in this series.
How ALL Poser versions that have the morph brush can work with FBM and HD morphs.
ALL Poser versions that have the Morph Brush can use FBM and HD Morphs.
Video number 4 in this series; Why do you have to delete and replace the object files Poser saves for you.
Why do you have to delete and replace the Poser saved obj files?
First of the new video series uploaded.
Poser2Blender2Poser 1 : The correct Poser and Blender Export -Import settings to get Poser groups and figures in Blender to create Morphs.
Poser2Blender2Poser 1 ; The correct Export-Import options
Next in the new series will be improved video's on how to detail the meshes, get some clothing over them, and general finetuning to get the most out of the Poser-Blender combination.
Have fun using the Poser - Blender tools. Best regards, Tony
