Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Here is the FBX file as it appears in Notepad if anyone can make any sense out of it.
http://mailpost.webatu.com/helicopter.html
You can copy and paste it into Notepad and then save it with a .FBX extension to try the import yourself.
It is showing all the signs of the axis but you could try this. Save a second copy of your project in Max and remove all the animation to isolate the prop itself. Export the FBX file the same as you have done and see if it is upright. I am wondering if it is not the animation data telling it where to be heading as a starting point.
- Johnny G
"Try animation to get things moving"
lpr001@renderosity.com
Sorry for the delay freemarlie. I don't think it will be an easy fix. Alembic would be the go but both Daz and SM offers this as a export feature only out to game engines etc. Where MAX you can go import and export same with HitFilm and a few others. Looking at the data I was left wondering what would happen if you changed the Y's to Z's and vice versa what would happen but would be more effort than animating the helicopter in Poser. I managed to change the configuration and reset the pivot to bottom center and have it land the right way up in Poser, but it makes it a starting point so the minute it starts to read the embedded files it will start to turn over.
- Johnny G
I never considered doing much animation in Poser. Threw in a couple of walk motions once but seems pretty straight forward and I have seen some excellent work done with the software. I had a render going so while I waited loaded a Bell helicopter and was pleasantly surprised at what could be done in little time. In the Poser library I loaded the pyramid because it gives you a nice directional tip to work with Loaded the helicopter and parented it to the pyramid in the same fashion you had in mind with the dummy import. I went in 500 frames and inserted a key to give the chopper time to get it's blades up to speed for the lift off and mapped out the course, used the dials to get a good movement on it and then went back and animated the main and tail rotors. Good part about a helicopter is the take offs are never that smooth LOL
- Johnny G
I tried to export an animation from 3ds Max into Poser via FBX but the orientation is all wrong. Does anyone know how to fix this issue?
Here is a video showing my problem. https://www.youtube.com/watch?v=M123Z766l_c
