Mon, Jan 27, 7:16 AM CST
Subject: A shirt forMicheal
mdbruffy ( ) posted Sun, 04 September 2016 at 12:52 PM ยท edited Sun, 26 January 2025 at 3:51 PM
Does anyone know of a shirt for Micheal 4 that has the same kind of open morphs that this safari shirt for Micheal 3 has? Wardrobe Wizard doesn't copy morphs. I'm using Poser Pro 11.M's shirt.jpg
EClark1894 ( ) posted Sun, 04 September 2016 at 1:02 PM
Have you tried to use PP11's Copy Morph command under the Figure Menu to copy from the shirt that has the morph to the one that doesn't?
mdbruffy ( ) posted Sun, 04 September 2016 at 1:12 PM
I tried. It won't acknowledge the correct shirt. If I load the original and then the conversion, the process will only acknowledge the conversion. Same if I load the conversion first.It won't copy from the original shirt. And if I delete the conversion, it won't acknowledge the original that's still on the screen.
raven ( ) posted Sun, 04 September 2016 at 2:25 PM
Wardrobe Wizard should convert the morphs, this is the M3 safari shirt converted to M4 in P11Pro. The only problem I had was with the shirt buttons, they didn't morph with the untuck morph, so I made them invisible.
mdbruffy ( ) posted Sun, 04 September 2016 at 2:31 PM
The untucked morph was what I wanted. I took a long shot and conformed the M3 shirt- and it was an almost exact fit to M4. I had to work with the sleeves and arms, But I finally got something I could use: Shirt fit.jpg
raven ( ) posted Sun, 04 September 2016 at 2:43 PM
That looks fine. A quick touch of morph brush could hide the small parts of M4's arms if necessary too.
mdbruffy ( ) posted Sun, 04 September 2016 at 2:46 PM
raven posted at 2:45PM Sun, 04 September 2016 - #4282178
Either that or just expand the sleeves a touch more.
