Sat, Jan 25, 11:58 AM CST
Subject: First upload
funhouse4jt ( ) posted Sun, 18 September 2016 at 12:21 AM ยท edited Fri, 17 January 2025 at 10:15 AM
Boni ( ) posted Sun, 18 September 2016 at 7:15 AM
You have a good start. What version of Poser do you have and I can direct you to your next step, if you like. I've used this program since version 3. (many here since version 1) and let me warn you ... it is addictive. Pleasantly so.
Boni
funhouse4jt ( ) posted Sun, 18 September 2016 at 10:24 AM
Poser 8.
hborre ( ) posted Sun, 18 September 2016 at 12:31 PM
Online Now!
Agree with Boni, a good attempt. But there is quite much more to grasp when in pursuit of realistic type renders. I suggest doing some research on gamma correction and linear workflow, this will help to improve both lighting set up and texture response to those lights. And I mention this because the model in the render is exhibiting a specular bloom which is typical of too much lighting on the stage. Gc will correct this.
ghostship2 ( ) posted Sun, 18 September 2016 at 1:10 PM
I had Poser 8 but can't remember it's limitations. Can you do GC in it? Can you do IDL? I had it for a few months and then upgraded to the pro version.
hborre ( ) posted Mon, 19 September 2016 at 4:40 PM
Online Now!
Unfortunately, P8 cannot do Gc, only the pro version. You would need to adapt BB's VSS skin shaders for figures and change Mat Room settings for other content to work correctly with your lights. I'm trying to remember if Snarly's older version EZSkin worked in P8. It's been so long ago.
ghostship2 ( ) posted Mon, 19 September 2016 at 4:54 PM
hborre posted at 3:54PM Mon, 19 September 2016 - #4283979
I don't believe it does. I think I started using ezskin when I got PP2014.
