Blender F.A.Q (Last Updated: 2025 Jan 05 8:18 pm)
Sorry if I'm stating the obvious, but don't you need to unzip it first?
TheBryster posted at 7:01PM Sun, 25 September 2016 - #4284785
No, you shouldn't have to. Usually with Blender add-ons if you use the "install from file" option in the user preferences Blender will unzip everything and put it where it goes. I just tried it with the Mitsuba exporter though and it doesn't work,exactly as the OP reported. The instructions for the add-on say to install it manually so I guess the normal process doesn't work with this add-on.
Here's the relevant section of the instructions:
Unpack this file and move the resulting mitsuba folder into your Blender scripts/addons folder. After restarting Blender and enabling the plugin in the addons preferences, you should be able to select Mitsuba as the currently active renderer. In the main scene tab, you will need to set the path to the main renderer executable (mitsuba.exe on Windows, Mitsuba.app/Contents/MacOS/mitsuba on MacOS, /usr/bin/mitsuba on Linux).
This process does not seem to work either though (at least in Blender 2.77), so I have no idea how you get this add-on installed.
Finally I try it again.I find it showed"MSVCR120.DLL" lost if mitsuba0.5 x64 was used.While mitsuba0.5 x86 is basically ok.I try it in blender2.70a x64bit.Why I choose blender2.70a because opengl is only 1.4 as blender said.`"However, Blender 2.76 and earlier still supports Windows XP and OpenGL 1.4 graphics cards.)".And after 2.77 or later,the system requirements is higher.My old pc ! And my old pc is very noised when running mitsuba render.If to add more detail materials to model ,CPU can be consumed more ,too. Anyway to try to test mitsuba render,which it is first time used.
This is way beyond me, I'm afraid.
And mitisuba render has some bugs
in blender. I first to see it,and I ever find it
rendered a cup with tea ,which the
render time is 40m but 40s.It is very
long render time.And pic has some
noise. I dont know the lonest render time is
what in blender? But it better then luxrender,which
luxrender eated CPU more and
more,and very slowly.Now I dont use
luxrender.
luxrender.
To add mitsuba but nothing.System
is 64bit.Mitsuba render cannot be
added to 64bit? Thanks.
