Wed, Jan 8, 12:46 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 30 12:17 pm)
banner
Subject: INJ file question
Darkworld ( ) posted Mon, 10 October 2016 at 9:16 PM · edited Mon, 06 January 2025 at 9:17 PM
Anyone know how you'd go about making a single INJ pose to load a bunch of custom morphs, but NOT set those morphs to 1. in other words load them up so morph poses would then work, but for the initial load you want them all set to zero.
Boni ( ) posted Tue, 11 October 2016 at 7:01 AM
If you have Poser 11 there is a simple way. I have to look it up ... but first, is it P11/PP11? Second are these custom morphs? (I assumed they were since they are injection morphs, but I"m covering all my bases).
Boni
Darkworld ( ) posted Tue, 11 October 2016 at 10:17 AM
Custom morphs made in zbrush, and I'm using Poser Pro 11. I've loaded them all onto a figure and they work great but I need to make an INJ so I can sell the pack, and need morphs to start at 0.
Boni ( ) posted Tue, 11 October 2016 at 12:35 PM
Here's the deal with P11. The morphs SHOULD show up in 0.0 in full body ... as well as each body part that is effected If you have applied the morphs to the entire figure in ZBrush at ONE time. If that didn't happen. In the manual pgs. 795 thru 818 you should find all the information you need. This section will give you additional options you may find useful. Main menu>help>reference manual. Just for reference, I am currently learning to create morphs for Poser in ZBrush myself.
Boni
Darkworld ( ) posted Tue, 11 October 2016 at 12:51 PM
Cool I'll check it out. I've been using a little python app called zscript or something that creates INJ poses from current morph settings on the figure, so any morph set to zero isn't saved.
Boni ( ) posted Tue, 11 October 2016 at 1:43 PM
Any one can contradict me and correct me if need be, but as I understand it ... when you bring the figure back from Zbrush using GoZ it automatically sets it to 0.0. A secondary script isn't necessary.
Boni
Darkworld ( ) posted Tue, 11 October 2016 at 1:51 PM
Never used GoZ I'll have to check it out
Boni ( ) posted Tue, 11 October 2016 at 3:04 PM
Ah, that will save you a lot of steps in this! You will like it!!
Boni
Boni ( ) posted Tue, 11 October 2016 at 3:06 PM
Be sure to use the GoZ listed under Figure in the Poser Menu, NOT object. Then it will come back as a morph. Check it out ... The Zbrush forum here has a good thread on that when I was learning now to do that.
Boni
Darkworld ( ) posted Tue, 11 October 2016 at 4:02 PM
Cool where do you get GoZ?
Boni ( ) posted Tue, 11 October 2016 at 4:04 PM
It is part of Poser Pro 11 (and Pro 2014 as well). You already have it.
Boni
Oh and it is built into Zbrush as well.
Boni
Darkworld ( ) posted Tue, 11 October 2016 at 4:10 PM
Ewwww nice ;)
