Mon, Nov 25, 8:33 AM CST
Subject: Bryce render to disk issue
Lobo3433 ( ) posted Wed, 26 October 2016 at 4:43 PM · edited Mon, 25 November 2024 at 6:42 AM
Forum Moderator Online Now!
OK I know Bryce is not a 64 bit app but last night doing some renders and I use to Render to disk all the time in my old system and never came across this issue before where the CPU heated up to temps above 80 degrees when I redid the render and used normal rendering mode at a lower resolution than what I was wanting then CPU temps were around high 60's found this to be very odd wondered if anyone has come across this before
Windows 10 Pro 64-bit
CPU Intel Core i7 6700K @ 4.00GHz
RAM 64.0GB Dual-Channel Unknown @ 1066MHz
Motherboard Gigabyte Technology Co. Ltd. Z170X-Gaming 7
Graphics 6144MB NVIDIA GeForce GTX 980 Ti (Gigabyte)
Thanks in Advance
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
TheBryster ( ) posted Fri, 28 October 2016 at 11:19 AM
All I can tell you is that Bryce is notorious for sucking up RAM like a baby elephant at a watering hole.
Is the CPU temps something that you need to be concerned about. I don't know at what point they become a problem on any PC. For myself, I would stick to normal render modes unless you really need a Hi-Def image. On the other hand, do you really need to render-to-disk? I'm usually content to just let is screen-render in the background.
Lobo3433 ( ) posted Fri, 28 October 2016 at 11:24 AM
In the past on my older machine which was also 64 bit much less memory I would do render to disk usually was faster and I could continue working on other things like surfing the web or such. Normally my new system since I use water cooling under normal load CPU temp stays between 28 to 34 degrees but now using the render to disk temp jumping to above 80 degrees just seemed not normal not sure why.
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
PoserUserFromRussia ( ) posted Sat, 29 October 2016 at 8:43 AM
I am interested in the result of the Bryce-test for the configuration of your computer. http://www.bryce-3d.narod.ru/bryce_test_multi_eng.html
TheBryster ( ) posted Sat, 29 October 2016 at 11:26 AM
Poseruserfromrussia, many thanks for your post. I'd forgotten about the use all core options in Bryce. Your link is very interesting.
Lobo3433 ( ) posted Sun, 30 October 2016 at 9:34 AM
Thank you I had forgotten about the use of core option as well here are my results from the test file
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
