Tue, Jan 21, 2:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: question
meltz ( ) posted Fri, 11 November 2016 at 3:10 PM ยท edited Mon, 13 January 2025 at 3:52 PM
I'm working on a project that will call for many different views of grungy city streets. What's the best way to go about this. Is there anything on the market that may help me achieve this?
SpookieLilOne ( ) posted Fri, 11 November 2016 at 3:52 PM
Changing camera angles...?
*~*Jamie*~*
SpookieLilOne's Storeย
SpookieLilOne's FreeStuffย
SpookieLilOne's Galleryย
"Life is just a dream on the way to death." ~The Crow: City of Angels
SamTherapy ( ) posted Fri, 11 November 2016 at 4:18 PM
Yup, Spookie's answer will get you there. Use the Dolly Camera, position and save using the Camera Dots, reposition, save with the Camera Dots again and so on. You can also save to the Camera Library. When you're happy with them all, select the one you want then render.
Simples!
meltz ( ) posted Fri, 11 November 2016 at 5:46 PM
Cameras I got that part. What about the city streets, anyone know of some on the market that has options to keep making them look different for many different sceans?
SamTherapy ( ) posted Fri, 11 November 2016 at 6:14 PM
I haven't seen anything but you could edit the existing textures, add a few props here and there, make new materials and so forth.
RedPhantom ( ) posted Fri, 11 November 2016 at 6:39 PM
Site Admin Online Now!
I don't know if they're grungy enough for you but dreamlandmodels has city blocks over at daz that are poser compatible. Each block has 4 sides so you have 4 sets of buildings.
Boni ( ) posted Sat, 12 November 2016 at 7:46 AM
Unfortunately all at DAZ:
Dirty City Streets
Look up "Stonemason" there and you have a plethera of street scenes, standard and grungy. See what you can do with those.
Boni
Kendra ( ) posted Sat, 12 November 2016 at 11:19 AM
I was going to suggest Dreamlandmodels too. I have a couple and even with just one or two blocks you can get a variety of looks.
...... Kendra
meltz ( ) posted Sat, 12 November 2016 at 12:00 PM
Thank you so much everyone. I'll go check it out :-)
LaurieA ( ) posted Sun, 13 November 2016 at 12:16 AM ยท edited Sun, 13 November 2016 at 12:20 AM
Check The Abandoned City 1 or 2, Derelict Corners Urban, The Dark Side of the City, Tin Pan Alley, The Backstreets and A Quiet Street by Stonemason at Daz for some dirtier, grungier streets. I don't mind selling Stonemason's things...he's really good with the grungier side of things and all the sets I mentioned will work in Poser. Newer sets will not.
ironsoul ( ) posted Tue, 15 November 2016 at 1:41 AM
Also to consider is using photo references for middle and far distance, saves the polygon count for filling the gaps between 3D buildings. Its straight forward to load these into a paintshop/gimp to add bump and spec so they blend better with the lighting. Sites like cgtextures have plenty of references
hborre ( ) posted Tue, 15 November 2016 at 10:57 AM
Online Now!
If you are keen to using existing sets as background, you can save to background in Poser which will create an image of your stage as a background.
stallion ( ) posted Tue, 15 November 2016 at 11:21 AM
There is also Everyday items, Street litter by 2nd_World here in the market place
You might as well PAY attention, because you can't afford FREE speech
ironsoul ( ) posted Tue, 15 November 2016 at 12:48 PM
Anyone looked at the OpenStreetMap project for this kind of purpose? Probably over complicated unless OP needs to do whole city sections. After watching a CityEngine demo I started looking at OSM export options for import into Poser but fell a sleep at the mention of xml.
ElZagna ( ) posted Tue, 15 November 2016 at 3:36 PM
Forgive me for playing junior moderator here, but it's very helpful to everyone to give your thread meaningful titles. "Question" tells us nothing. This applies to this and all forums.
OS: Windows 10 64-bit, Poser: 10
SamTherapy ( ) posted Tue, 15 November 2016 at 3:55 PM
Predatron has City Streets at DAZ. Fairly low poly, IIRC.
