Mon, Jan 20, 11:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Poser 11 Cloth Room Problem
ElZagna ( ) posted Mon, 14 November 2016 at 12:38 PM ยท edited Mon, 20 January 2025 at 9:12 AM
I just installed Poser 11 and can't get cloth simulations to work. It runs through the simulation just fine but at the last frame the item snaps back to its default position.
OS: Windows 10 64-bit, Poser: 10
RedPhantom ( ) posted Mon, 14 November 2016 at 1:07 PM
Site Admin Online Now!
Do you have all the updates installed? I think the last one helped that.
EClark1894 ( ) posted Mon, 14 November 2016 at 1:09 PM
Remember that technically all the sims are just frames of an animation. What happens if you just drag the dial to the last frame or the frame just before that?
ElZagna ( ) posted Mon, 14 November 2016 at 1:58 PM
Updates are good: Poser 11.0.5.32974.
I've tried going back to a previous frame, but they are all reset to the default position.
PhilC ( ) posted Mon, 14 November 2016 at 4:32 PM
How many frames for draping do you have? How many cloth simulation frames do you have?
EClark1894 ( ) posted Mon, 14 November 2016 at 4:34 PM
Can I see your Cloth room settings? Also, your pose you want to have at the end.
ElZagna ( ) posted Mon, 14 November 2016 at 4:55 PM
Well, it couldn't be simpler. Ultimately it came down to a single dynamic piece colliding with the ground and I accepted all the defaults. It all still works in P10, so I have to believe this is a P11 issue. I'll submit a report to SM.
ElZagna ( ) posted Tue, 15 November 2016 at 3:31 PM
I contacted SM support and this is apparently a known problem. The workaround is to do a Save As... before running the sim. I had noticed that my old sims worked, so this makes sense.
