Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 12:41 am)
Oh, bugger. :(
Thanks, mate. Just had an idea, may or may not be relevant...
My old copy of WW is still in an external Runtime, would that cause a conflict, or other error? Not using it though; I'm using the one built into PP2012.
Here it is. I haven't a Scooby what it's telling me, apart from there's an error. :)
Timestamp: Thu Nov 17 18:36:51 2016 pathname C:UsersPaulPoser Pro 2012RuntimePythonposerScriptsPhilCWardrobe Wizard P9
singleSelectPATH ['C:\Users\Paul\Poser Pro 2012\Runtime\Libraries\Character\M2\M2 Clothes\Basic clothes\Suit Coat.cr2'] batchSelectPATH C:UsersPaulPoser Pro 2012RuntimeLibrariesCharacterM2M2 ClothesBasic clothes outputfolder C:UsersPaulPoser Pro 2012 fromtype 0 hires 1 forceanalysis 0 keepmorphs 1 regroup 1 fixpopthru 0 proponly 0 breastpuff 0 looseness 10 fromfig M2 tofig [u'M3'] bodymorphs 1 flared 0 closeFit 1 RegroupHarder 0 MatDials 0 copyWeightmaps 0
Converting the following 1 files C:UsersPaulPoser Pro 2012RuntimeLibrariesCharacterM2M2 ClothesBasic clothesSuit Coat.cr2
Progress: 33% done. Elapsed time: 0.00 mins. Time remaining: 0.00 mins Hi res analysis ZClothing_MilMan_blSuitCoat.dat being created, one moment please... -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Error!
With Poser closed, try finding ZClothing_MilMan_blSuitCoat.dat Delete it. Open Poser and try again.
Its a long shot but worth a try.
Also try opening the original coat's OBJ file in a text editor and see if you can find any anomalies. Usually in the form of bad characters, Chinese? I've seen them slip into the start of the "f" lines section.
Will do. Meantime, I tried converting the P4 Male Tuxedo to M3 and got exactly the same error. Makes me think it's not a problem with the OBJ. I'll still take a look, as you suggest.
Trying to convert the M2 suit coat to M3 gives the following error:
Error! Traceback (most recent call last): File "C:UsersPaulPoser Pro 2012RuntimePythonposerScriptsPhilCWardrobe Wizard P9m0.py", line 11, in ww.ChooseMenuItem(0) File "C:Program FilesSmith MicroPoser Pro 2012RuntimePythonposerScriptsPhilCWardrobe Wizard P9ww.py", line 5167, in ChooseMenuItem File "C:Program FilesSmith MicroPoser Pro 2012RuntimePythonposerScriptsPhilCWardrobe Wizard P9ww.py", line 569, in Print UnicodeDecodeError: 'utf8' codec can't decode byte 0xfe in position 964: invalid start byte
Any ideas?
Poser Pro 2012, Win 7 Pro 64 bit.
