Thu, Jan 9, 3:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 2:14 am)
Subject: textures turning blue
chaylastorm ( ) posted Thu, 17 November 2016 at 7:48 PM · edited Thu, 09 January 2025 at 3:19 AM
Hi, I thought I would dig my Poser 10 out of moth balls and start some texturing again... however my textures are turning blue and I'm not too sure what to do about it. I have made sure that the .png out of Photoshop is fine.. it's only when I go into 'materials' and try to add it to the model. It looks to me like a 'path' or 'gamma' thing.. says someone who doesn't know much about it. LOL Hope that someone here can help me. Lets see what do you need to know... Poser 10... Photoshop CS2 (I know.. old huh?) and I'm still using Mac.. Snow Leopard 10.6.8 Thanking you in advance. :) Screen shot 2016-11-18 at 9.29.09 AM.png
LPR001 ( ) posted Thu, 17 November 2016 at 7:53 PM
Take it out of PS as a jpeg and see what happens
- Johnny G
"Try animation to get things moving"
lpr001@renderosity.com
chaylastorm ( ) posted Thu, 17 November 2016 at 9:20 PM
Thank you so much Johnny G... it's been so long that I had forgotten that. :( Have just tried that and it work... yahhh. :)
ironsoul ( ) posted Thu, 17 November 2016 at 11:59 PM
I get this problem when exporting png from Substance Painter, the advice was that Poser doesn't support 16bit but I never found a solution and still use IrfanView to batch convert png to png. Would be useful to find out the correct png format to load in Poser as it provides better quality than jpeg
chaylastorm ( ) posted Fri, 18 November 2016 at 12:07 AM
Thanks Ironsoul... that could be a solution also.. will have to look into it. I know that almost everything I do is in .png and I am sure I used to use it when I last used Poser and Photoshop.. nothing has changed there.. still using all my old programs.. so it's just going to be a case of trial and error I guess. :) Still I aren't going to be doing heaps.. just me playing. LOL
LPR001 ( ) posted Fri, 18 November 2016 at 5:09 AM · edited Fri, 18 November 2016 at 5:10 AM
@ironsoul Check this out and see if it works. You can change the color depth and dpi under advanced down bottom right corner FastStone
You will want the Photo Resizer app at the bottom
- Johnny G
ironsoul ( ) posted Fri, 18 November 2016 at 6:51 AM
LPR001 posted at 12:39PM Fri, 18 November 2016 - #4290339
Many thanks Johnny I'll check it out.
chaylastorm - same experience with Substance painter to Poser, it used to work (except normal maps). The trouble was both Substance Painter and Poser went through an update cycle at the same time and I assumed it was a problem with SB based on their release notes.
SamTherapy ( ) posted Sat, 19 November 2016 at 7:54 AM
Ah, you have selected "Smurf Mode".
I'll get me coat.
