New Poser Users Help F.A.Q (Last Updated: 2024 Nov 04 9:21 am)
No, Genesis 2 requires the use of DSON it is a free tool you can find on Daz's website.
*~*Jamie*~*
"Life is just a dream on the way to death." ~The Crow: City of Angels
DSON should only need one install. I have never used it but I am sure you could Google for a tutorial on the process
*~*Jamie*~*
DSON will import DAZStudio .duf format files into Poser, however, not all content are designed to import correctly. Firstly, check if the DAZ content can be used used in both DAZStudio and Poser. A good number of Genesis 2 content can be used in both application, but there are many that are designated for DAZStudio only. Read the content page carefully before committing. Although, converting the content shouldn't be a problem, you will need DAZStudio installed and an understanding on how to proceed with a conversion. Secondly, if the content can be used in both applications, there should also be Poser Companion Files available. Both DAZ Companion Files and Poser Companion files are necessary and should be installed for successful DSON importation. They should also be linked to Poser.
D3D does have a free DUF loader which works very well in Poser. With this added to Poser, you should not need to install DAZStudio.
Can I simply install, download, a G2 item into PP 2014. Where will it go as there is only a Runtime in Poser? Thanks.
