Wed, Feb 5, 11:59 AM CST
Subject: Outside of Poser, what do you use to create groups for rigging?
rokket ( ) posted Sat, 03 December 2016 at 5:01 PM · edited Wed, 05 February 2025 at 11:59 AM
I want to try to group something for the first time. I usually just bring the prop into setup and allow Poser to autogroup and then use a donor DEV rig. I decided it was time to learn all of this myself. I will be looking for tutorials, but I would like suggestions on what you use to create groups for rigging.
What I have available to me:
Wings 3D Blender (not really good with it) 3DS Max (I've had it for a month and can use the UVW Unwrap, that's about it) UV Mapper Classic (I know, it's fairly useless)
So, what do you use?
The arm is what I want to rig. It only had 3 fingers and I want it to move in a very specific way. I've already rigged the legs. I think the torso section will also be fairly easy, as will the spinal implants on her back that you can't see...
SamTherapy ( ) posted Sat, 03 December 2016 at 5:22 PM
I don't. Not with hard surface modelling, anyhow. Here's how I do it, all without the Setup Room:
Make my model in Wings.
Once the model is completed, assuming it's all in separate pieces, I assemble it in Wings. There's a scale discrepancy which I take care of when importing to Poser.
Export each moving piece as obj, map as necessary.
Import to Poser, all options unchecked. PhilC's obj Import Plus is a great help with this.
Set up the hierarchies. Once that's done, select the main part and scale that to Poser size.
Then hit the "Create New Figure" button, wait for Poser to do its magic. New Poser, then load the newly created figure. Save out again, since Poser doesn't (usually) keep the newly created obj past a full shutdown.
Reload, adjust the joints and bends.
Open Cr2Editor and do any other necessary tweaks.
Save.
Simples.
rokket ( ) posted Sat, 03 December 2016 at 5:31 PM
I've tried that with another model. While it worked beautifully, I couldn't conform it to the figure I'd created it for and had to settle for parenting it to the figure. Still did what I needed it to do, but in this case, I'd need it to conform, and for that I will need to group it, but group it specific to what I am trying to do vice what Poser will do.
SamTherapy ( ) posted Sat, 03 December 2016 at 5:35 PM
Ah. Never tried making conforming stuff. Sorry, bud.
rokket ( ) posted Sat, 03 December 2016 at 5:40 PM
No worries. I might still try to do it with the hierarchy editor later on. I will have to take the model apart and rename each piece. When I exported it out of Wings the first time around, I combined all the pieces first.
tonyvilters ( ) posted Sat, 03 December 2016 at 5:50 PM
I had a tutorial on youtube some time ago. Then I redid all my tutorials, but this one is still on the "to do" list.
Next week, promised.
=> Check Poser2Blender2Poser under my name, there are 5 (or 6) video's there. :> It will be for Blender.
rokket ( ) posted Sat, 03 December 2016 at 5:54 PM
Cool, Tony! Thanks! I'll check that out.
PhilC ( ) posted Sat, 03 December 2016 at 6:02 PM
Don't underestimate UVMapper, it is what I use to do my grouping.
tonyvilters ( ) posted Sat, 03 December 2016 at 6:18 PM
Euh, . . . . . waiting for that tutorial, I advice to look at Video 1 and Video 4 !!! The others are not relevant for this purpose.
You will learn what the setup-fitting room does to your obj files.
rokket ( ) posted Sat, 03 December 2016 at 6:25 PM
PhilC posted at 4:25PM Sat, 03 December 2016 - #4291844
I know, Phil. But I don't have the pro version. I've only got the classic. It doesn't do the same things.
rokket ( ) posted Sat, 03 December 2016 at 6:26 PM
tonyvilters posted at 4:25PM Sat, 03 December 2016 - #4291846
I subscribed to your channel. I will check those out after Poser gets done with a huge render I am running.
PhilC ( ) posted Sat, 03 December 2016 at 6:28 PM
I use it to select faces with the marquee tool and assign them to a group. Does the free version have that option?
rokket ( ) posted Sat, 03 December 2016 at 6:42 PM
No, it doesn't.
AmbientShade ( ) posted Sat, 03 December 2016 at 6:49 PM · edited Sat, 03 December 2016 at 6:50 PM
If you have Poser 10 or higher then you can use the grouping tool. It got a complete revamp in Poser 10. That's what I use for most of my grouping work. For small areas that are hard to see/get to with Poser's crap-tastic cameras (and their inability to focus on a specific area of a non-rigged model), use blender to assign materials, but that's really only necessary if you're doing things like eyes and teeth.
Here is a video I did earlier this year all about the grouping tool.
https://www.youtube.com/watch?v=A1IdI7ZsXKI
rokket ( ) posted Sat, 03 December 2016 at 6:50 PM
PhilC posted at 4:48PM Sat, 03 December 2016 - #4291849
Oops. My bad. I can select facets and assign them to a group. I don't know about individual faces, however. I clicked and dragged to select a section. I will play with it a bit more and see what it can and can't do.
rokket ( ) posted Sat, 03 December 2016 at 6:51 PM
AmbientShade posted at 4:51PM Sat, 03 December 2016 - #4291855
Thanks, Shane. I do have Poser 10. I will check out the video. I was avoiding Poser on purpose because I didn't like the grouping tools.
tonyvilters ( ) posted Sat, 03 December 2016 at 6:54 PM
OK, the "create vertex groups in Blender" just got Prio 1.
PS; PhilC, I used the same technique as you did because it is fast and easy.
AmbientShade ( ) posted Sat, 03 December 2016 at 7:02 PM · edited Sat, 03 December 2016 at 7:04 PM
rokket posted at 7:59PM Sat, 03 December 2016 - #4291857
The process will be virtually the same regardless of which program you use. You still have to select individual faces and assign them to a group. So if you can do it in Poser then it saves time and eliminates risk of import/export errors. The grouping tool also makes it easy to mirror groups from one side to the next and rename them. And if you don't spawn new props then you don't have to worry about the broken groups that Poser will export.
Teyon ( ) posted Sat, 03 December 2016 at 7:34 PM · edited Sat, 03 December 2016 at 7:34 PM
Modo and uvmapper pro
infinity10 ( ) posted Sat, 03 December 2016 at 11:54 PM · edited Sat, 03 December 2016 at 11:56 PM
Best for me is Shade 3D.
Mixamo - a no-brainer for hopeless riggers like me (but groupings tend to be FBX style). Blender 3D also good.
Eternal Hobbyist
tonyvilters ( ) posted Sun, 04 December 2016 at 5:40 AM
You"ll see , it is a walk in the park in Bender. I just have to re-build a video-demo-purpose-build dress today because the YouTube time limit only allows for 15 minutes for free videos. So I have to demo it all in just under 15 minutes; LOL. Failsafe and super easy.
rokket ( ) posted Sun, 04 December 2016 at 5:48 AM
Okay, I'll check for it tomorrow Tony. I have to meet my wife. We are going to the bar I own because we are interviewing some new waitresses...
ProPose001 ( ) posted Sun, 04 December 2016 at 12:48 PM
Pegasus, is also an option. Available at Daz
Letterworks ( ) posted Sun, 04 December 2016 at 6:56 PM
Autogroup editor is an older program but still does a good job. I has a 3d display, can transfer groups from a donor, and then you can tweak them as you want. You can also create your own groups. The interface and mouse are a bit different but easier to get used to.
https://www.renderosity.com/mod/bcs/autogroup-editor---the-advanced-group-editor-for-poser-clothes-modelers/21081/
adh3d ( ) posted Tue, 06 December 2016 at 5:40 AM
I use the "loop cut" in wings3d, put the target figure and the cloth, make the cloth transparent material buy with wireframe, and them, cut the mesh as close as you can respect the target mesh.
adh3d website
rokket ( ) posted Tue, 06 December 2016 at 6:07 PM
adh3d posted at 4:05PM Tue, 06 December 2016 - #4291973
Wow, I never even thought of that. Thanks! I'll give that a try if I can't get anything else to work.
I am attempting to rig the left arm, which is the cyborg arm. I want the parts to twist and rotate without affecting the other actors. It's been hard to pull off so far. I can make it a stand alone figure and parent it to Miki, but her real arm is still there, just hidden.
rokket ( ) posted Tue, 06 December 2016 at 6:14 PM
So, as you can see from this preview render, right now I rigged it using Miki 4's DEV rig. There is some distortion in the joints that shouldn't be there.
I am not solid as a rigger, and I am not sure how to set limits and create the dials to make it more robotic and less organic, which it is right now...
