Sun, Feb 2, 7:10 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Poser 11 Pro 11.05 on Macintosh
inquire ( ) posted Thu, 15 December 2016 at 3:14 PM · edited Sat, 05 October 2024 at 12:08 AM
Just went up to Mac OS 10.12.2, Sierra, on Tuesday, when it was released. Then I updated from Poser 11 Pro 11.02 to v. 11.05. What happens is that when I start Poser, the Library (floating) panel shows up as completely blank. There's no way to search for a Runtime folder or anything. Then, I quit Poser, and then restart. The Library then appears with Runtime folders in it. Is there any way to avoid or correct this strange behavior? I sure hope it doesn't go to a blank Library panel permanently. It's a little unnerving to see it do that.
By the way, I also have Poser 2014 Pro on my HD, and it starts up with the Library operating fine, with the Runtime folders showing.
ironsoul ( ) posted Thu, 15 December 2016 at 11:08 PM
Have you searched the Poser forum, I've seen mention of this or a similar problem posted there. The answer I saw was to select the refresh button found bottom right.
inquire ( ) posted Fri, 16 December 2016 at 3:38 PM · edited Fri, 16 December 2016 at 3:42 PM
Oh, a different Forum? Oops, sorry if I posted this in the wrong place. OK, I'll look for another forum, and I'll keep in mind a refresh button found bottom right. (Seems like the entire Library panel is blank, but I'll check.) Thanks.
You are right, ironsoul: There is a greyed out Refresh button in the bottom right corner. I clicked on it, and all the Runtimes appeared in the Library. Thank you very much.
