Thu, Nov 28, 3:11 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 26 6:59 am)
Subject: Daz 4.6 Material Presets - How to Get Them?
flibbits ( ) posted Mon, 02 January 2017 at 9:37 PM · edited Thu, 28 November 2024 at 3:10 AM
I'm new to Daz Studio (using 4.6). While trying the Genesis 3 characters, I've installed the content by hand. The figures load - Genesis 3 Male and Female, Michael 7 - but there are no material presets for anything in the surface tab.
Where can I find those presets?
How can I enable them?
How do I install content so the presets appear?
Medzinatar ( ) posted Tue, 03 January 2017 at 1:31 AM
First off, you are 3 builds back. You should upgrade to at least 4.9.2.70
Your terminology is a little confusing. The Surface tab shows what materials are attached to a figure or object. It does not have any presets. For Genesis 3 figures, material presets are located in Content library under either materials or characters.
You should consider using the DAZ Install Manager to install content. When configured properly , all your content should be available and it makes it easy to have multiple runtimes.
Medzinatar ( ) posted Tue, 03 January 2017 at 1:39 AM
My Content Library looks like this.
Razor42 ( ) posted Tue, 03 January 2017 at 6:08 PM
Just as a small note to add to what Medzinator has written.
The surface tab does have a Presets panel also and relies on correct categorisation of each asset to display Material and Shader presets from within the Surfaces Tab.
bhoins ( ) posted Fri, 06 January 2017 at 8:51 AM · edited Fri, 06 January 2017 at 8:52 AM
Razor42 posted at 7:51AM Fri, 06 January 2017 - #4294283
This is absolutely correct.
It is like the Smart Content tab. Note you also should have a surface selected. :)
bhoins ( ) posted Fri, 06 January 2017 at 8:53 AM
As already pointed out. 4.6 is really old. Please update for the bug fixes, if for nothing else.
jestmart ( ) posted Fri, 06 January 2017 at 7:52 PM
Can you even use Genesis 3 in 4.6?
bhoins ( ) posted Fri, 06 January 2017 at 10:15 PM · edited Fri, 06 January 2017 at 10:18 PM
jestmart posted at 9:15PM Fri, 06 January 2017 - #4294549
Sort of. IIRC, it has been a while.
flibbits ( ) posted Fri, 27 January 2017 at 2:47 PM
I was confused. I was using 4.8. I was talking about materials - they're in the materials folder.
Razor42 ( ) posted Fri, 27 January 2017 at 5:47 PM · edited Fri, 27 January 2017 at 5:53 PM
Genesis 3 Materials are located in /People/Genesis 3 Female/Materials. To apply a material preset select the Genesis 3 Figure in the scene then locate the required material preset in either smart content or the content library tab and double click the preset.
If you are talking about files in /runtime/libraries/Materials they are Poser Material files and not fully compatible with DS. Apparently PZ2 is more compatible than MT5, which will not work at all. But expect that any Poser Material if compatible will need some work in DS, especially if rendering in Iray
Also Material presets are configured for Specific surface names so a rock material preset will only work on that specific rock with the correct surface names and will not apply to any other item. A Shader preset will apply to any surface selected in the surface tab.
