It's a plain intersecting a 3d model. Not a water or particle simulation. You can model an indention in the water plain pretty easily. You will have to do that in a modeler like wings or Blender.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
You could also use Blender's sculpting mode or Sculptris to sculpt the water around the boat. As long as your plain is a dense enough mesh. You could even add wake other cool watery details :)
Albert Einstein
Depending on the geometry of the plane, you might be able to use a magnet or the morph brush to create the dent, but it needs to have enough polygons to do it.
seachnasaigh posted at 12:23PM Sat, 14 January 2017 - #4295106
A displacement map or a transparency map could also work,
That's the first thing I thought of, followed by the magnet idea. In fact, a combination of displacement, magnets and wave deformers can create a very good look for water.
Another solution is to make two renders- one with and the other without the water. You can then use a clone brush in you favourite paint software to replace the 'wet' interior with the 'dry' one, Cut and paste a selection is also an option
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu, 16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
A displacement map works nicely. If you have to animate, you can move the water with the boat. Assuming the water plane is a simple rectangle, it will be 'sliding under' the banks, and the turbulent surface will look like waves breaking on the shore.
My python page
My ShareCG freebies
I have a canoe prop. Just a canoe, nothing fancy. I have a water plane. When I put the canoe ON/IN the water it's fine, as long as it's on the very top of the water plane. When I sink it a little, for the weight of the people, it is carrying the canoe 'sinks' beneath the water, but you can see the water inside the canoe if you peer over the top. Of course I cheated and put the camera lower so you can't, but I was wondering if there was a way to keep the water out of the boat.
Thanks.
