Mon, Nov 25, 2:06 PM CST
Subject: Hand following hip, animation problem.
xpdev ( ) posted Thu, 09 February 2017 at 2:42 AM · edited Mon, 25 November 2024 at 2:06 PM
Hi
i have made a simple animation with 150 frames, just to show my problem.
I'm not able to find the way to make following V4 hip with left M4 hand
I have seen a lot of movies with hand perfect following another figure body part, but i'm becoming crazy to find the right way to do this without repositioning M4 hand using poser dials frame by frame....
any help would be appreciated
Following you see the first and the last frame.
Here is the simple project, standard V4 and M4 figures only:
https://www.dropbox.com/s/ieivxt2an2q4h77/Anime.zip?dl=0
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
xpdev ( ) posted Thu, 09 February 2017 at 2:49 AM
i have forgotted, i'm using Poser Pro 2014
RedPhantom ( ) posted Thu, 09 February 2017 at 6:04 AM
Site Admin
It's a simple matter of turning the Ik on for mike's hand and parenting it to the hip.
And you really shouldn't upload scenes like that for people to download. It's a copyright violation.
raven ( ) posted Thu, 09 February 2017 at 6:11 AM · edited Thu, 09 February 2017 at 6:21 AM
Position M4's hand on V4's hip. Then try turning Inverse Kinematics on for M4's arms and then parent his hand to V4's hip. His hand should now follow V4's hip. Like this.
xpdev ( ) posted Thu, 09 February 2017 at 7:36 AM · edited Thu, 09 February 2017 at 7:36 AM
Sorry for copyright violation, i did not know
Asap i'll do same test and then report it here.
Thanks to all
Kazam561 ( ) posted Thu, 09 February 2017 at 11:00 PM
I would suggest uploading any files as an avi, rather than a .pz3, showing the problem rather than uploading the files. However, if it's a pose you've created on your own, I'm not sure about a copyright violation. People do give away free poses here and on other sites legally.
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
Richard60 ( ) posted Thu, 09 February 2017 at 11:03 PM
Also you can use constraints instead of parenting. see this video https://www.youtube.com/watch?v=QNjWK9SO9c4
xpdev ( ) posted Fri, 10 February 2017 at 1:08 AM
Thank you to all, now works fine.
SamTherapy ( ) posted Fri, 10 February 2017 at 3:50 AM
RedPhantom posted at 9:49AM Fri, 10 February 2017 - #4296995
How so? AFAIK, scene files don't contain the obj of any figure. You'd need to have the originals installed to make use of the PZ3.
Kazam561 ( ) posted Fri, 10 February 2017 at 1:52 PM
SamTherapy posted at 1:52PM Fri, 10 February 2017 - #4297057
That's what I was thinking too... thanks Sam. Also thanks for the info everyone.
