Mon, Dec 23, 7:44 PM CST
Subject: Change in V4's setup??
VolcanicMink ( ) posted Sun, 05 March 2017 at 5:22 PM · edited Mon, 23 December 2024 at 7:31 PM
I have reloaded V4 straight from the DSON, but now I only have 3 icons under the Pose menu. V3.PNG There used to be a 4th with just her mug shot, which was what I used to get V4 on the screen. The one I have here was just for V3 last I knew. v4 missing.PNG I have removed and downloaded 7 times, restarted the computer, disk-cleaned, defragged, everything I can think of. I have run the batch file, and still the morphs won't work, probably because they're not made for V3. Please help!! I'm running out of hair to pull out!!
willyb53 ( ) posted Sun, 05 March 2017 at 6:16 PM
I can not help you with V4, but IIRC there should be a seperate morph inj for v4 to v3 Bill
Sa_raneth ( ) posted Sun, 05 March 2017 at 6:27 PM
try downloading her manually see if that helps
Helos ( ) posted Sun, 05 March 2017 at 6:48 PM
Yes, Sa_raneth is right. you should install V4,2 manuelly.
That's my download:
I don't know, what the "Dev-files" can do.
Henning
Kazam561 ( ) posted Tue, 07 March 2017 at 2:39 AM
I think the Dev-files are for those who want to try developing content. Installing manually should get you all the files, but you should put in a ticket with their help desk. They might not be aware of the DIM not installing that content any longer. On the other hand, they have dropped most older V3 content. I for one just picked up a texture for V3 last week from another website.
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
WandW ( ) posted Tue, 07 March 2017 at 10:03 AM
If you install her manually, make sure to reinitialize her afterward...
