Sat, Jan 11, 5:06 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 11 7:56 am)
Subject: background prop
Marque ( ) posted Sun, 05 March 2017 at 9:12 PM · edited Sat, 11 January 2025 at 5:05 PM
Haven't been in in a long time. I used to have a prop in an older version of Poser that allowed me to put a background pic in. Is there a way to do this in Poser Pro 11 without a prop or do I need to buy a new item. Wanting to put a pic of a room I'm working in and add items like furniture and such. Thanks in advance, Marque
donnena ( ) posted Sun, 05 March 2017 at 9:26 PM
You can always apply an image to a one-sided square....
Poser 11 gives you lots of new toys in the Props/Primitives folder....
Happy Rendering!
Andy!
Marque ( ) posted Mon, 06 March 2017 at 12:44 PM
Yup knew about that guess I didn't explain well enough. Thank you for answering.
Marque ( ) posted Fri, 10 March 2017 at 5:10 AM
How do I apply the image? I haven't played with poser for a while and have forgotten everything it seems. I loaded the one-sided square and went to the material room but can't figure out where to create a node of the actual image.
hborre ( ) posted Fri, 10 March 2017 at 7:29 AM
Material Room: right-click anywhere for the menu, go to New Node, select 2D Textures>Image_Map. Load your texture through the Image_Source of that node. Connect the node to DIffuse_Color, setting the Diffuse_Value to 0, and Alternate_Diffuse. For the image to look correct, scale the rectangle x & y to the image resolution dimensions, then perform an overall scaling for stage placement.
hborre ( ) posted Fri, 10 March 2017 at 7:33 AM
Need a visual aid, I can provide one. Just ask.
