Try framing the object first and then scroll to zoom in and out. I've noticed that sometimes you have to frame an object before zoom will work.
You might also try looking in the shortcuts menu to see if you can find zoom listed there and what the correct key combination is. You can get to the edit shortcuts menu in preferences under the interface tab.
I don't know what the various differences are between a pc and mac tho, so I can't really be of much help beyond that.
I had problems when I installed logitech mouse software on my macbook pro. it switched zoom and up down. (It still did all the same scroll just with different hot keys. I did not like it) I ended up uninstalling the software and just using the mouse without it on my mac. now I still use the logitech mouse with native os x mouse controller set to natural scroll in system preferences. Also I assume you have scroll to zoom checked in poser preferences interface tab.
scroll wheel zooms in and out. shift+scroll moves left right. cmd+scroll moves up down. alt+scroll rotates up and down. alt+shift+scroll rotates left and right.
also ... with camera selected cmd+left mouse button drag to zoom in and out. (If an actor is selected the action will be performed on that actor ie. character, body part, prop)
also ... alt+left mouse button drag - to rotate camera (no matter what actor is selected)
also ... space bar+left mouse drag - to pan camera (no matter what actor is selected)
So I am using poser on a mac, and pretty much ever since I got it, the zoom has worked by holding down command and then scrolling on my mouse. But recently it has stopped working. I'm not sure if I accidentally hit one of the other keys once and messed it up, but I would have no idea which one I might've hit and why it would've messed up zoom. Now whenever I scroll while holding down command it just acts like I'm not holding down command and just moves up and down. Does anyone know how to fix this, and what I might've done to make it stop working? Thanks
