Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
it's something to do with the SSS option. i installed lululee's update from 2016, that includes an SSS version of her textures. but that didn't work.
i went to the girl's texture library, and chose her non SSS skin/mat files. and then did the lingerie and it worked. but i still would like help getting a fix for the SSS.
Unfortunately that would break the shader, my workaround is to apply the non sss skin texture, add the overlay and then run Snarly's Ezskin script to add the sss. In this case it might add the sss to the clothing so might look odd. Do you recall where the advanced shader script is available, if its free I could download it and see what's doing.
Regarding it not running in Poser 11. Did you reinstall the product when moving to P11 or just reuse the existing runtime? If the latter then it might be worth doing a re-install, A problem I find when upgrading Poser is python scripts need to be reinstalled (they go into the runtime Poser sets up for itself not the user content runtimes)
1 - Disconnect Edge_Blend_4 from value 1 of Blending_Diffuse_Color
2 - Plug your subsurface skin node into Value 1 of Blending_Diffuse_Color
3 - Disconnect Blending_Diffuse_Color from PoserSurface Diffuse_Color Plug Blending_Diffuse_Color into PoserSurface Alternate Diffuse (thus disconnecting Subsurface Skin)
As it looks now, seems your node setup is actually bypassing the overlay (which I'm assuming is Image_Map_6.
Consider me insane if you wish, but is your reality any better?
Well not actually bypassing, but it isn't plugged in to your alternate diffuse and the defualt diffuse is set to 0 since there are nodes plugged into Alternate_Difffuse. The Blending_Diffuse_Color (which is what provides the mixing of the texture and overlay) is plugged in to the 0 Value diffuse only. Which is why it's not appearing.
Hi, I've been away from the computer and just returned. The lingerie set requires semidieu's FREE Advanced shader plugin. semidieu made it available for FREE at Daz. Go to Daz and type in his name and go to his store. You will see it there for FREE so you can add it to your cart and download it. Install it in the base Poser SOFTWARE you are working in. For instance if you are running Poser 11 install in Poser 11. Please contact me if you have any problem. Cheerio lululee
i use P11, and i've got a typical V4 character up nude. i have had lululee's fancy lingerie second skins for awhile but always have trouble loading them up. the only way i could do it was to open P9, load up my girl, add the ss, save, then load it back up in P11 and render that way. same with the tattoos from shana c.
i just tried that method today, and it isn't working. when i look in the nodes in the material room, i see the image map for the lingerie i wanted connected there. but for some reason it's not showing up in the PoserSurface node.
i've been working with poser since P4, but i am NO pro! i'm really hoping there's some box i haven't checked off somewhere. help would be appreciated, mew.
