Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
hi Bunyip02
there's a few shaders for the eyelashes, cornea transparency, and eyemoisture transparency
in the carrara shaders tab under presets, shaders, skin, genesis 3 carrara, janette and johnathon
if there's a eyelashes with the creature, you would need to go to shader room and give the shader the path to the alpha mask
the iray opacity doesn't come over to carrara.
cheers
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Ty Wonga
i just bought the 3du pixie for g3m, just to see if success or fail >.<
I had trouble 3DU Captain Charisma... the suit won't follow the G3 Captain body morph but will follow all other body morphs.. weird
I had to detach the Charisma suit bones in Carrara export as OBJ import into DS and transfer assets from G3 then do the usual... that worked.
will be interesting to see if the 3DU pixie does the same.. was a toss up between that and charisma for me yesterday on which to buy.
Find my Facebook Page Here -- or me on Twitter
Star 2 for g3f has her own uvs set. uvs are in the vendor's folder "littlefox"
she comes with extra geometry for eye lens, and eye socket. Trying to load the Eyes crashed carrara.
rendered with the star's uvs, without the extra lens and socket Calling it a semi-success .
think i forgot to change the iris uvs (doh)
Ty diomede
so far, is the g3 winter dress and capt carisma
i could try making a fix for the winter dress,
Misty's product is awesome. I've been buying a lot of G3 content and trying it in Carrara. Most items work well after converting them.
I seem to have a lot of issues with shoes and feet. When they're first loaded they work fine, but after saving them in Carrara and then opening the file, parts of the shoes seem welded too the floor. Shadowcat (first image) has distortion in the feet and the last image shows the weird feet issue. I usually just reload the shoes every time I open the file. A pain, but workable.
Skin shaders seem a little dull and grayish. Is that because of lack of SSS? Any hints on improving skin tones.
cute superheroes.
hey there georgie!
there are carrara shaders out for genesis and genesis2, think is by ringo, could try those settings on g3 skins.
the shoe thing might be due to the extra toe bone that acts like a body handle for all the individual toes.
well, uvs arent the same,
use the shader ""settings"", but swap in george's texture maps .
there's also the hollywetcircuit's trick, was on carrara cafe, i'm having trouble finding it again >.<
yeah. it doesn't let you apply a shader without changing the texture map, would make our carrara life easier lol
i set my render settings high, slows a render, but, still faster than iray.
my dream is vray for carrara.
If you have Misty's G3 character preset that loads in Carrara, this thread can be a place for people to list G3 items that can be used along with it. Similarly, can list loading failures.
A good format might be
Item, by artist, for Figure, loads fine and conforms well
or
Item, by artist, for Figure, loads but does not conform well - perhaps it can be used with VWD
or
Item, by artist, for figure, does not load.
Example Tutu, by Diomede, for Freak 7 (fictional), loads and conforms well
