Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Jamy, the main thing is making clothing and hair Carrara friendly as well as tweaking shaders, most Carrara users are used to the latter, there are a lot of missing maps.
For the clothing and hair you need DAZ studio,
All you need to do in most cases is load the clothes in DAZ studio by clicking them , some have a preset that loads a whole outfit.
No figure is needed in the scene in fact best not as if not Johnathon or Janet could crash Carrara.
then select each garment and go to edit/figure/rigging convert triax/general weight to blended weight
then under file save as scene subset
you can select your figure in carrara and load that scene subset from your library or by file and it will fit and apply morphs for each garment and hair in turn.
wendyvainity posted at 10:54AM Thu, 30 March 2017 - #4300878
Thank yoo
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
wilgrfx posted at 10:56AM Thu, 30 March 2017 - #4300898
Misty, Just wanted to let you know that Janette and Johnathon are gone from my wishlist and are now mine. Thank you, thank you... I keep mumbling while stumbling off to bed.
Ty
i hope you enjoy them
not yet, its a matter of finding someone with scripting knowledge that uses Carrara and wants to use Genesis 3.
would not need to be DAZ script or Carrara more of a batch notepad hack on the duf files,
Someone like Dimension 3D prob could do it but AFAIK they have no interest in Carrara.
MJCasual might even who knows? Or maybe Fenric?
just putting it out there as a suggestion hoping someone can as I am sure all of us would buy it if put on the marketplace here.
a quick look in notepad at an uncompressed file reveals "binding_mode" : "Blended", instead of "binding_mode" : "General", is the crucial line needed, the word dual Quart is still actually present however most duf files are compressed so unsure how one can do this unless one batch unzips them with 7zip maybe first Find and replace on an unaltered scene subset should have worked but did not so it gets more puzzling
theres an 18 percents coupie out
i'm not a 100% sure on tongue poses, didnt have any packaged tongue poses to test. tongue parts are poseable, works with carrara rotation wireframe
the rest of the face rig works.
really hopin someone would package up some nla clips
Fantastic product, just bought it but I keep getting this error when I try to use it: "Warning: file /data/DAZ 3D/Genesis 3/Male/Genesis3Male.dsf could not be found Warning: file /data/DAZ 3D/Genesis 3/Male/Genesis3Male.dsf could not be found Error: node /data/DAZ%203D/Genesis%203/Male/Genesis3Male.dsf#Genesis3Male not found"
Genesis 3 works fine in DAZ studio. Do I need to move some files?
Any tips?
joeping posted at 4:40PM Sat, 01 April 2017 - #4301214
Any tips?
I re-installed Genesis 3 starter essentials for male and female and everything works great. Now the fun can begin :)
G3 ears and pecs/breasts are pose-able
wonder how would look animated with oscillate tweener
Great product, and very easy to use.
This is my first experiment with using a Genesis 3 figure in Carrara 8.5 Pro using "CarrarActors, Janette and Johnathon for Genesis 3 in Carrara 8.5". It uses the "Darius 7" morphs and textures, "Classic Trenchcoat for Genesis 3 Male(s)" and "Diesel Hair for Genesis 3 Male(s) & Female(s)". I then applied a Genesis 3 aniblock that I converted to a NLA clip.
It is rendered at 1920x1080 @ 30fps and averaged 15 sec per frame to render.
he's having a good stretch.
with all his mouth rigging could give a big yawn
joeping posted at 8:47PM Sun, 02 April 2017 - #4301324
Thank you MistyLaraPrincess, With all that mouth rigging it works great with Mimic Pro for Carrara.
I tried a quick test with Mimic Pro for Carrara and a "Toon Generations 2 Female for Genesis 3" figure rendered with "LuxusCore Carrara"
cute poet
Ty for sharing
joeping posted at 9:20AM Mon, 03 April 2017 - #4301347
Thank you MistyLaraPrincess, I am loving your product. I had to try an experiment with Mimic Pro for Carrara, Mr. Bear and Son for Genesis 3 Male(s) and Carrara hair. It's something that I could never have done in DAZ Studio :)
beary fun
There's 16 of us now, G3 in Carrara
organizing my bandicam schedule for the weekend. (they online activation only, i have to record in 10 minute segments )
without specific things to focus on, i'll putz around trying out g3 outfits and hairs. playing with zolly doom, camera panning.
didn't understand how tricky camera panning techniques are, til i became serious about my movie project. 72 hours to render a camera pan of the mystic gorge,
but that's what practice if for!
knitting mittens
started working on a couple outfits, will be setup for Janette and Johnathon, - no converting needed
bronie outfits?
Bunyip02 posted at 6:08PM Mon, 10 April 2017 - #4302056
RawArts new Gigalien for G3M.
cant help notice his toothy smile
oh, if i right-click, open image in new tab, i sees it full size!
the next CarrarActor i'se workin on. almost finished.
CarrarActor Samantha for Janette / Girl 7
They strolling the Venice set
did everyone make their own shaders for Jeanne and Eddie?
was thinking of mebbe adding helper shader for Jeanne and Ed (the default G3M/F skins) to the d/l files.
diomede posted at 10:42PM Fri, 28 April 2017 - #4303839
With sufficient modification, I believe that I am allowed to offer a Carrara G3M skin shader based on ForbiddenWhispers resource, but I will check with the artist. Not sure how Ringo was able to offer Carrara shaders for Daz characters that relied on their maps. Will inquire.
nice resources from FW.
have this nice looking mr in my w/l, Genesis 3 - Master Beard Resource
i made 2nd skin templates, using old wings3d 99.5, it has the color faces option, think they took it away in later versions.
don't want to bake it into the skin though, surely the rara shader tree can handle it as a layer?
is everyone making out okay saving character uvs presets - V7 M7 etc?
MistyLaraPrincess posted at 6:13AM Sun, 28 May 2017 - #4304275
I must admit I've been putting off installing "Janette and Johnathon". I've a question before I do... I have a folder called "3rd Party content" where I keep everything away from where your documention says to install to. Thought I'd better as if it's ok to install to the other folder?
Have a coloured pencil... color me puzzled.
if your genesis 3 (male and female) starter essentials are in the 3rd party folder, should be okay.
the carrara folders can go in any "shader" preset folder
video tut covers how to link daz content folders in carrara
MistyLaraPrincess posted at 8:27PM Sun, 28 May 2017 - #4306189
No... starter essentials in main DS Libraray... so will install there. Whew... that's what had me worried... didn't want to create problems for myself.
Thanks MistyLP
lookin forward to seeing your renders
MistyLaraPrincess posted at 2:45AM Mon, 29 May 2017 - #4303827
Forgot to ask... Did I miss something... please let me know more about Jeanne and Eddie. Probably mentioned earlier... if so I'll just go back page or so and find out.
jeanne and eddie are the skin textures that come with the genesis 3 starter essentials.
their ds shader presets are aoa shaders, aoa shaders are dark in carrara.
i think most of us are loading the maps manually in carrara, and then saving it to carrara's browser tray.
i like to use the carrara shader shown in 'holly wet circuit's specular hightlights video tut. originally found it on carraracafe site. good stuff there!!!
looks like they spiffed up the cafe.
i cant find the holly video tutt naos
MistyLaraPrincess posted at 6:13PM Mon, 29 May 2017 - #4306225
Holly Rocks! Perhaps I'll take a look for later also. Right now fingers is twitching... haven't modeled anything in a few days... and need to create something for the current Carrara Challenge.
Do 3DL textures for skin also use AoA? Just bought a G3F Char, uses 3DL, from Digital Creations.
Also I hasa lot of skin shaders bought for Carrara only.
Hmmmm. AoA = AgeOfArmor... hehee
wilgrfx posted at 8:55AM Wed, 31 May 2017 - #4306292
Just wanted to let you know that I just grabbed Girl 7 Pro bundle in preparation for CarrarActor Samantha for Janette.
kewl!
was some nice sale yesterday. i grabbed Gia 7 and Arabella 7.
is it a deal breaker?
the anatomical pro bits?
working on a preset for Michael 7's willie. it has the same uvs mess issue all the geografts have. haven't given up on making a preset for it yet, but it does seem futile right naos.
MistyLaraPrincess posted at 6:49PM Wed, 29 March 2017 - #4300818
That would be awesome, can't wait for that!!
