Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 11:35 am)
thats a problem with the settings of the textures in the matlab and the light.For the best settings of the textures,there are several tutorials available.have a look here in the tutorialsektion or at www.brycetech.com, or go to the bryceforum,where these probs are dicussed several times. for the lighting I myself put a conelight near the camera so that the person gets some light from the front
When you get the hang of it you will find that bryce renders will be better than poser(I think so at least..).Make sure to add light,the standard light wont do and play around with the reflectiveness of the armour tex..if you dont know how to there should be a tut about somwhere here...also remember that transparancy doesn't automaticly work from poser to bryce(eyes and hair for exmp )
Also, turn down the ambience. Usually everything imports in Bryce with the ambience cranked way up. I think in Bryce 5 gamma correction is off by default. If not, turn off gamma correction, skin tones look much better. You'll also need to manually apply the trans maps. You can also change the sun position, color, and shadow intensity in the skylab. Hope this helps!!
There are a lot of things worse than dying, being afraid all the time would be one.
