Sun, Jan 5, 10:29 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
Subject: Morph Slider greyed out
Bullet572 ( ) posted Fri, 31 March 2017 at 11:19 AM ยท edited Sun, 05 January 2025 at 10:17 AM
Hello to everyone,
I have huge Problem with my Daz3D assets, as I bought some assets, which are, for the most part anyway, loading fine. But some of the assets either don't appear in my library or they appear but, the Morph sliders are greyed out (hidden).
For example if I'm applying the Work Hard Lingerie from outoftouch to lets say Victoria 7, the clothing fits fine, but I'm not able to do any of the available Morphs, as they are greyed. Even searching for new files, re-importing the metadata, or trying to apply the Morph script manually doesn't do anything.
All of the files are located in the correct Folder, so there shouldn't be an issue. But I just can't figure out, how I can get the sliders to appear and to actually Change the Outfit in any way.
I had such a problem with the Female Body Morphs, which disappeared, when I set the Database to reset, search for all files again and re-imported the metadata. But as for the Outfits, that doesn't help. I hope someone as any clue, how I can fix this Problem.
best regards Bullet
Jack238 ( ) posted Fri, 31 March 2017 at 12:51 PM
Hi, I am not sure which items you are having trouble with but I had a similar issue with some items where the morphs were greyed out. In my case the morphs were not at the level of the item I had highlighted (selected) in the scene tab. As an example, if this was Victoria 4 selected, and some of the morphs were greyed out, selecting something like the head would make some of those morphs not greyed out, (Like the ones pertaining to the head, eyes, mouth etc.)
You might want to try to select any sub-items of the item to see if that helps with your problem. Not sure how applicable this is, but your problem seems close to what I experienced.
Bullet572 ( ) posted Fri, 31 March 2017 at 1:28 PM
I tried that, but it doesn't help. For some reason, those Morphs I'm looking for are working with clothing for Genesis 2, but not with the Genesis 3 clothing. To be honest, it's all about the clothing from outoftouch. The Thing is, it's nice that Gen 2 is working, but I spent a lot of Money for all my Gen. 3 assets and characters (like Bethany). Compared to these assets I have almost nothing for Gen 2.
RHaseltine ( ) posted Fri, 31 March 2017 at 3:06 PM
The greyed out properties are hidden - you have Show Hidden Properties on in the pane's option menu. That means they are not intended to be used directly, though that wouldn't usually stop them entirely. What morphs are they? If they are pose controls that drove special bones (for tails in hair, perhaps, since you mention OOT) and you have used AutoFit to move the item to a different figure then the bones they were driving will have gone. With hair it may be better not to fit but simply to parent and adjust the scale and translation, or user a Smoothing Modifier with translation, to get it snug
Bullet572 ( ) posted Fri, 31 March 2017 at 3:47 PM
Actually it's not really a specific Morph, that doesn't work. The issue is, that all morph sliders for any Piece of clothing doesn't work, although I can see them if I let Daz Show hidden properties. Even if I unhide them, they don't do anything, at least with a Genesis 3 model, with all Genesis or Genesis 2 models it works perfectly. I mean sure, there are some things, that are far worse for me (GPU Rendering only with nVidia Cards f.e.), but I just can't figure out, why I can "edit" clothing for Genesis 2, but not for 3.
RHaseltine ( ) posted Sat, 01 April 2017 at 3:59 PM
Are you sure they are morphs?
Bullet572 ( ) posted Sat, 01 April 2017 at 5:26 PM
Yes, I'm sure, that they are morphs.
RHaseltine ( ) posted Sun, 02 April 2017 at 9:59 AM
Could you give a couple of examples I can try checking, assuming I have the content.
