Wed, Feb 26, 2:49 PM CST
Forum Moderators: wheatpenny Forum Coordinators: Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 25 7:07 am)
Subject: Texture Conversions
arrow1 ( ) posted Fri, 14 April 2017 at 9:00 PM · edited Mon, 10 February 2025 at 7:19 PM
Is it possible to change some JPG textures I have made to IRAY compatible? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
RHaseltine ( ) posted Sat, 15 April 2017 at 9:17 AM
Images don't need conversion as such, though the properties they are controlling may not carry over. What is it you want to convert?
arrow1 ( ) posted Sat, 15 April 2017 at 4:06 PM
I have made some skin texture modifications and I want them to be IRAY compatible. Cheers
RHaseltine ( ) posted Sun, 16 April 2017 at 1:44 PM
Do you have the unmodified versions as Iray materials? If so in the Surfaces pane click the mini-thumbnail next to the colour picker/strength slider for the property, select browse from the menu, and load the modified version of the map.
arrow1 ( ) posted Sun, 16 April 2017 at 6:12 PM · edited Sun, 16 April 2017 at 6:12 PM
At the moment I only have the textures saved in the textures folder as png's and jpg's. Cheers
RHaseltine ( ) posted Mon, 17 April 2017 at 9:49 AM
The you need to apply them through the Surfaces pane, in the Editor tab, to the properties they control - click the little button next to the colour/strength slider and then use Browse to load the map. By default a newly imported mesh will use the Daz Default Shader - for a purely Iray material you will probably want to apply the Iray Uber Base shader, which you can do by having the model and the Surfaces selected and then clicking the preset in the Presets tab of Surfaces, under Shaders>Iray
jdstrider ( ) posted Tue, 18 April 2017 at 3:00 PM
Once you have the desired texture maps in place and the Iray settings how you want them, you can save them as a Material Preset (See the File menu) Then the next time you want to use it, you can simply load the mesh and double-click the Preset that you saved. In the case of a Character, you could also use the Save as Character Preset which will remember the material settings as well, then you can just load the character with the iray maps and settings in one go. Remember where you save the presets... so you can find them the next time you want to use them!
